| 914Wes |
Jun 30 2026, 12:34 PM
Member ![]() ![]() Group: Members Posts: 55 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
4-Bolt 108mm Stub Axles + Output Flanges for 5 lug conversion
Up for sale: 4-bolt 108mm stub axles and matching 901/911 transmission output (joint) flanges. This is the classic combo for running the bulletproof GKN/Loebro 108mm CV setup on a 914 conversion. Why this combo: The stub axles slide directly into an early 911 wheel hub (same bearings as 69-73 911) and the output flanges bolt straight onto a 901/911-style transmission case. A well-known path for guys doing V8/big-six swaps who want to ditch the factory weak 914 CV's for the stronger 108mm 911/930 joints. Commonly cross-referenced to Porsche part numbers 901.332.232.00 (stub axle) and 901.332.209.15 (output flange). Available separately or as a set:
Good used condition, ready to clean up and install. CV joints not included — pair with a set of early 911 axle assemblies (donor CVs) to complete the swap. Payment: Venmo or Zelle Shipping: At cost — est. $20 USPS within the US. Worldwide shipping available, PM for an international quote. PM with questions. —Wes |
Lo-Fi Version | Time is now: 30th June 2026 - 09:31 PM |
