| zaballosc |
Jul 8 2026, 07:38 PM
Newbie ![]() Group: Members Posts: 23 Joined: 31-August 15 From: Whitewater, WI Member No.: 19,118 Region Association: Upper MidWest |
Hi all!
Been having a no-start issue, and had my car taken to a well-regarded 914 shop. They informed us that their policy is that they only use brand-new parts that they source themselves. Outside of the no-start issue, it appears that the NOS fuel injectors that we had put on it are leaking, alongside the short hoses leading to them. We just replaced the whole fuel system with Tangerine Racing stainless lines with new rubber. They said that the tiny rubber lines are backordered, and the injectors run about $500 per. I'm confused, as I see hundreds of listings for part FJ67 for $120 online. Am I missing something here? Let me know if i am overreacting. |
Jul 8 2026, 07:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,046 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Find a new shop that isn’t intent on scamming you.
PS - send your injectors to Mr Injector. He will test & clean them. If they are truly leaking and aren’t worth cleaning he will not charge for them. |
| bkrantz |
Jul 8 2026, 08:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,775 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
| JamesM |
Jul 8 2026, 11:23 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,304 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
wow....
Actual cost on FJ67s is less than 100 bucks a piece. 500 if they were talking the whole set maybe. Shops only installing parts they source is not uncommon, but those prices are out there. I don't have the factory book in front of me at this exact moment but I know even factory book time to replace 4 injectors was less than 2 hours. The elbows are an absolute non issue, even if you don't know 914s. Worst case replacing all the fuel lines in the engine bay at the same time with good German braded stuff you are still under 1000 bucks. |
| emerygt350 |
Jul 9 2026, 04:08 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,729 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
And a no start condition from leaking injectors? Maybe a bad start. The fj67 are great
Even Mr injector thinks they are a fine replacement. |
Jul 9 2026, 04:57 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,904 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I've had Bill at Mr Injector service hundreds of injectors for me. For what he charges, it's worth getting done if only for spares.
There are shops that charge big money for normal stuff and people open their wallets. That's fine if you have a big wallet and are ok with their work. There is a lot of stuff on our cars, like changing injectors, that can be done with very basic tools in very little time. I'm certainly no tech but I've changed out injectors and it was easy. Smart move going with the Tangerine products. No start issues are usually something simple. Air, fuel spark. |
| GregAmy |
Jul 9 2026, 05:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,700 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
| rick 918-S |
Jul 9 2026, 06:19 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,339 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Is it possible you misunderstood the per injector quote? Is it in writing? Strange.
| DC_neun_vierzehn |
Jul 9 2026, 11:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 677 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Hi all! Been having a no-start issue, and had my car taken to a well-regarded 914 shop. They informed us that their policy is that they only use brand-new parts that they source themselves. Outside of the no-start issue, it appears that the NOS fuel injectors that we had put on it are leaking, alongside the short hoses leading to them. We just replaced the whole fuel system with Tangerine Racing stainless lines with new rubber. They said that the tiny rubber lines are backordered, and the injectors run about $500 per. I'm confused, as I see hundreds of listings for part FJ67 for $120 online. Am I missing something here? Let me know if i am overreacting. I recently went through replacing all 4 injectors, the 4 injector rubber elbows (which I believe is what you’re referring to as “short hoses”), and all rubber lines in engine compartment. I had never done this work on any car including my 914. The FJ67s were about $125 each. The spool of correct high pressure fuel injection Barricade line was less than $100. While the 914 FI elbows are “out of stock” in most 914 online parts vendors there is an easy, inexpensive solution. Click on my profile name and search “member’s topics” to get those details and links. You can get 4 injector elbows for less than $20. Total time to install everything (with proper FI clamps) for a novice like me was about 4 hours. Someone who’s done it before, probably half that or less. Total amount spent for everything above less than $600 months total. Thus, that shop is trying to rob you blind. As others have suggested, send your injectors to Mr. Injectors for inspection, analysis, cleaning. Then go from there. I would find a 914 member near you to put the injectors and elbows on for the price of a case of beer or a nice bottle of wine. Plenty of fine folks here willing to help. I would help if you were near me. |
| emerygt350 |
Jul 9 2026, 12:29 PM
Not sure why people are saying the elbows are not available. These are the injectors that have been on my car for 5 years without a problem.
https://a.co/d/0ewGMaEj |
| windforfun |
Jul 9 2026, 03:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
2.4 K$ is rediculous. Shop around dude. They're actually pretty easy to replace. Just don't smoke while you're doing it.
(IMG:style_emoticons/default/biggrin.gif) |
| Osnabruck914 |
Jul 9 2026, 05:27 PM
Member ![]() ![]() Group: Members Posts: 214 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Going to a "professional" shop is the absolute last resort for doing anything on our cars. I was recently quoted $1,500.00 for a rear wheel only alignment and they were going to do it via the "string and jack stand" method. Took it home and did it myself for nothing- results 'perfect'.
Osnabruck914 |
| worn |
Jul 9 2026, 05:41 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,648 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Hi all! Been having a no-start issue, and had my car taken to a well-regarded 914 shop. They informed us that their policy is that they only use brand-new parts that they source themselves. Outside of the no-start issue, it appears that the NOS fuel injectors that we had put on it are leaking, alongside the short hoses leading to them. We just replaced the whole fuel system with Tangerine Racing stainless lines with new rubber. They said that the tiny rubber lines are backordered, and the injectors run about $500 per. I'm confused, as I see hundreds of listings for part FJ67 for $120 online. Am I missing something here? Let me know if i am overreacting. They only use brand new parts that they source would sound better if the injectors were the problem. Not at that price of course. But I don’t see why they want to replace the injectors rather than fixing your car. |
Jul 9 2026, 06:24 PM
Hi all! Been having a no-start issue, and had my car taken to a well-regarded 914 shop. They informed us that their policy is that they only use brand-new parts that they source themselves. Outside of the no-start issue, it appears that the NOS fuel injectors that we had put on it are leaking, alongside the short hoses leading to them. We just replaced the whole fuel system with Tangerine Racing stainless lines with new rubber. They said that the tiny rubber lines are backordered, and the injectors run about $500 per. I'm confused, as I see hundreds of listings for part FJ67 for $120 online. Am I missing something here? Let me know if i am overreacting. I don’t know if my shop is well regarded but I wish that new parts were a guarantee of success. Unfortunately, it just means they are clean and shiny. There isn’t one new part that we buy for these engines that hasn’t come mis-sized, defective, broken or just wrong. Sometimes an original refurbished or restored part is the only acceptable solution. For example: we don’t use uro head temperature sensors because they suck. They cost about $100. We use real Porsche branded head temp sensors. They are around $300. So my tech installs one yesterday and it was working for a bit and then doesn’t. We know it’s the new sensor because when he installs a good used sensor, the car runs right. Sometimes throwing new parts at the problem isn’t the solution. Air, fuel and spark make the engine run. |
| zaballosc |
Jul 10 2026, 07:06 PM
Hey all! Thank you all for the advice. A 914 world member is picking up the car and will be swapping in a spare distributor and FI setup.
Dodged a bullet - they tried to get us to swap to carbs TWICE! |
| wonkipop |
Jul 11 2026, 12:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,704 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Hey all! Thank you all for the advice. A 914 world member is picking up the car and will be swapping in a spare distributor and FI setup. Dodged a bullet - they tried to get us to swap to carbs TWICE! you sure did. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) i picked up a set of NOS injectors about 5 or 6 years ago for my L jet. which are co-incidently shared with the beetle of slightly later. i got them off a guy in arizona who had them in his cupboard sitting there for his beetle cab he no longer had. 60 USD each. the key was the injectors need to be still sealed in their plastic bag. which they were. and still in their boxes as a bonus. worked beautifully. helped he had stored them in a dark cupboard. but unless still sealed in plastic bag, NOS means nothing. still work beautifully. not sure what your mechanics were up to but it sure sounded like up to no good. |
Jul 11 2026, 09:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 917 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Hey all! Thank you all for the advice. A 914 world member is picking up the car and will be swapping in a spare distributor and FI setup. Dodged a bullet - they tried to get us to swap to carbs TWICE! This is the way. (IMG:style_emoticons/default/biggrin.gif) |
| ctc911ctc |
Jul 11 2026, 08:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Rock Auto shows them for 43 and 100 - depending on core? Still, you can do pretty well with just a few clicks. Also, I did the ORIGINAL and sent to Hurst-Injectors in Worchester MA, works great since I got them back!
| TheCabinetmaker |
Jul 12 2026, 08:51 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
wow.... Actual cost on FJ67s is less than 100 bucks a piece. 500 if they were talking the whole set maybe. Shops only installing parts they source is not uncommon, but those prices are out there. I don't have the factory book in front of me at this exact moment but I know even factory book time to replace 4 injectors was less than 2 hours. The elbows are an absolute non issue, even if you don't know 914s. Worst case replacing all the fuel lines in the engine bay at the same time with good German braded stuff you are still under 1000 bucks. James, I've had several cars with the braided hoses seeping gas thru the cloth braid after the inside rubber deteriorated from ethanol gas. I stopped using it many years ago. |
| sithot |
Sep 14 2026, 01:09 PM
Member ![]() ![]() Group: Members Posts: 452 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None
I bought a set of 4 FJ67's a few years ago when an original hose gave up and started leaking.
Replaced the one without looking at the other 3 I ordered. My mistake. I ended up with 2 having a straight run hose and one with the "90 degree" hose. Recently, I'd been seeking some "busy work" and I started only to find my plans were sabotaged. I called to Bill and he asked me about the color of the bodies. I told him two were black and one was shiny at the business end. All the numbers on the injectors were identical, but the boxes were different. He was curious as was I but neither of us had a good answer. He did offer some advice for using what I have by using a spring inside the bore of the hose allowing it to bend without kinking. Why didn't I think of that? (IMG:style_emoticons/default/headbang.gif) I highly recommend using Bill Johnson/Mr. Injector for your work. Very enjoyable to chat with and knows his stuff. |
Lo-Fi Version | Time is now: 14th September 2026 - 01:45 PM |
