> Ev14 injectors, Experience?
Flyinlow
post Jul 9 2026, 08:46 AM
Flyinlow
Region Association: Canada
Has anyone had experience/ success with the billet rails and the”ev14” plug and play system for 74 2.0 from Injector Rehab ? Does this stuff require some other modification as mine clearly doesn’t work. (IMG:style_emoticons/default/headbang.gif)
Craigers17
post Jul 9 2026, 09:10 AM
What part of the setup isn't working specifically? I notice one difference in the injector installation of yours vs Injector Rehab is that they have the part that receives the electrical connector orientated at about 80? degrees or so with reference to the runner, whereas yours is pretty much in parallel. I know @914Sixer was working on this setup a few years back. Maybe he has some input?
Flyinlow
post Jul 9 2026, 09:47 AM
Flyinlow
QUOTE(Craigers17 @ Jul 9 2026, 08:10 AM) *
It’s not the fitment they fit perfect and the injectors can be rotated easily… the car will not start with these installed
GregAmy
post Jul 9 2026, 09:51 AM
Are those high impedance or low impedance injectors? What is your engine management system?
Flyinlow
post Jul 9 2026, 10:11 AM
Flyinlow
QUOTE(GregAmy @ Jul 9 2026, 08:51 AM) *
Stock 74 2.0
post Jul 9 2026, 11:24 AM
You will have to change the injector plug ends to match the new injector is what I was told. You can have these, need your shipping info.
Flyinlow
post Jul 9 2026, 12:31 PM
Flyinlow
QUOTE(914Sixer @ Jul 9 2026, 10:24 AM) *
The stock ones plug in fine (IMG:style_emoticons/default/confused24.gif)
Flyinlow
post Jul 9 2026, 03:56 PM
Flyinlow
QUOTE(Flyinlow @ Jul 9 2026, 11:31 AM) *
Does anyone know what all the numbers represent I know the 0280-158 but don’t know the pressure or flow rate … I believe they are too much flow??
- Lo-Fi Version Time is now: 10th July 2026 - 02:46 AM
