| bajafreaks |
Jul 9 2026, 02:09 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I need to replace the flexible vent fuel lines coming from the tank to the engine compartment at both locations where they go through the inner fender area to the longs and then from the longs to the engine compartment. What size is this line??? and who sells it ? couldnt find at 914 rubber or AA.
it's obviously large for gas line. Thanks |
| bdstone914 |
Jul 9 2026, 08:20 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,334 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I need to replace the flexible vent fuel lines coming from the tank to the engine compartment at both locations where they go through the inner fender area to the longs and then from the longs to the engine compartment. What size is this line??? and who sells it ? couldnt find at 914 rubber or AA. it's obviously large for gas line. Thanks I rhink the lines you describe are 12mm. Put a pair of calipers on the tube OD. |
Lo-Fi Version | Time is now: 10th July 2026 - 02:47 AM |
