> Strange inward deformation?, My 1974 914-4 has a strange anomaly
Jezibel
post Jul 12 2026, 01:02 PM
Das Echte POORSCHE Fahrer
My 1974 914-4 has a strange anomaly that I cannot figure the cause of. [See attached 4 images of the left rear lower side panel.]
When I first got the car it had this unusual inward turn to it, assuming it had been somehow bent inwards a slight bit, so I manually pulled it back into normal conformation again.
However, in the course of driving the car's once--week 10 mile course (that includes a fast sweeping right turn freeway onramp) and returning to the garage, that panel seems to always want to resume that weird inward turn-in on that lower right rear panel (just in front of the wheel arch...between the left-side jack point and the wheel arch).
I haven't the slight idea what is causing this. The car has been "restored' and repainted a few years back, with any and all rust issues (if any) carefully addressed and rectified, but I am drawing a blank to explain this particular panel 'glitch.'
As usual, any and all insights and inputs on what may be behind this would be greatly appreciated. Thanks!
Attached ImageAttached ImageAttached Image
post Jul 12 2026, 02:19 PM
Pull the rocker and take pics. Unless you have pics of the restoration, anything could have been done to that area. Structure could be failing, etc. there is a problem but it will need some more digging to see what it is.
Also, take some pics at belt level, looking at the back of the car
post Jul 12 2026, 04:32 PM
Is there a rubber washer ~4mm thick between the rocker and the fender? There should also be one in the front.
The rockers are very weak in that last rear ~foot as the lower reinforcement fold is notched away to clear the rear suspension.
My view on this: (IMG:style_emoticons/default/rolleyes.gif)
The rocker is riveted the whole length of the door sill, then is not supported for that last ~1ft and held at the back anchor point (black arrows in the picture).
If the car flexes at the jack point (classic weak area), The fender will pull the rear anchor point up and will force the rocker to bend at the yellow arrow #1. This would induce a deformation on the rocker which, due to its natural bevel shape along the lower line of the car, would make the lower rear end to bend inward.
Again... just a theory for what it is worth... (IMG:style_emoticons/default/laugh.gif)
Jezibel
post Jul 12 2026, 05:53 PM
QUOTE(mepstein @ Jul 12 2026, 01:19 PM) *
Copy that, MEPSTEIN. Thanks. I'll do that.
Cheers, -Jezibel
SirAndy
post Jul 12 2026, 07:01 PM
Resident German
That's a lot of shims on that corner too. May just be a bent trailing arm, could be previous accident damage too.
Jezibel
post Jul 12 2026, 08:17 PM
QUOTE(Montreal914 @ Jul 12 2026, 03:32 PM) *
And that, my friend, looks like a very nice job of sleuthing! It certainly sounds quite reasonable, and as I said, the car is put through a long 'sweeper' on-ramp that I usually take at speed (thus putting some significant force on that left rocker rear section. I'll check the rubber grommet tomorrow, and also see if this seems like it might explain that strange inward bending anomaly. Thanks! -Jez
Jezibel
post Jul 12 2026, 08:21 PM
QUOTE(SirAndy @ Jul 12 2026, 06:01 PM) *
Another useful insight, SirAndy. Tomorrow I'll take a much closer look at all this. Hope it isn't a bent trailing am (as you suggest). Cheers, -Jez
bkrantz
post Jul 12 2026, 09:23 PM
If you mean the rear end of the rocker panel, I had the same thing on a previous 914. You can remove it to make it straight, and then when you remount it make sure none of the hardware is twisting if.
Chris914n6
post Jul 13 2026, 02:34 AM
Jackstands are my life.
There should be a ~5mm rubber grommet between the rocker panel and fender lip at the bolt, rear and front. If the under door section was riveted to the lip as factory, then your rear is being pulled upward - explains the twist.
5 User(s) are reading this topic (2 Guests and 1 Anonymous Users)
2 Members: Gustl, bdstone914
- Lo-Fi Version Time is now: 13th July 2026 - 03:00 AM
