> Headliner, Glue?
jfort
post Jul 12 2026, 02:38 PM
New (refurbished) and a new headliner. I thought I had used a good spray adhesive (3M?) but the headliner keeps falling. What’s the trick?
post Jul 12 2026, 02:46 PM
Higher strength 3m. There are a couple different levels.
wonkipop
post Jul 12 2026, 02:49 PM
i use this stuff these days for contact adhesive applications.
its very good.
better than 3M i have found. not that 3M is bad, but this gear appears to be that little bit better.
but its more $
you got to follow the directions.
the usual drill. clean both surfaces thoroughly.
degrease as well. metholated spirits or iso propyl alc for that final clean.
then get the timing right on the tackiness.
the stuff i use comes in a can and is not sprayed on.
i have never seen it in a spray can form.
you got to use a brush.
its almost impossible to clean the brush after use - so i have a packet of disposable brushes.
aharder
post Jul 12 2026, 04:12 PM
QUOTE(mepstein @ Jul 12 2026, 03:46 PM) *
(IMG:style_emoticons/default/agree.gif) I used The High Strength 90
post Jul 12 2026, 10:06 PM
QUOTE(wonkipop @ Jul 13 2026, 08:49 AM) *
its very good.
but its more $
Sika make some fine products so you will be safe there ,never had any luck with spraycan adhesives mainly on fabric like the headlining or other porous materials .
Mine had come unstuck on one corner so I used ADOS F3 gel contact with a brush and still good after 3yrs ,cheers
- Lo-Fi Version Time is now: 13th July 2026 - 02:59 AM
