> Is this trailing arm bracket toast?
burlybryan
post Jul 18 2026, 03:49 PM
Hole is elongated. I could weld it up and re-drill if needed.
HFC3
post Jul 18 2026, 06:54 PM
There’s certainly people on here that could have that welded it up and then re-drill it.
That hole obviously needs to be dead nuts. I believe that is the one set point on the trailing arm that has no adjustment.
bkrantz
post Jul 18 2026, 08:13 PM
QUOTE(HFC3 @ Jul 18 2026, 06:54 PM) *
Unless you want some "adjustment". I might have known people who might have gotten more camber in near-stock race 914s by "moving" the hole.
post Jul 18 2026, 10:10 PM
@burlybryan
date='Jul 18 2026, 02:49 PM' post='3265550']
[/quote]
Replace it.
Which side is it?
Can you show a whole picture of it?
I have a few..
post Jul 19 2026, 03:58 AM
[quote name='bdstone914' date='Jul 18 2026, 09:10 PM' post='3265574']
@burlybryan
[/quote]
Replace it.
Which side is it?
I have a few..
[/quote]
What does the end of the pivot shaft look like that was caused that oval hole? My quess it it iams damaged. Is it grooved or are the serations on the end worn off?
burlybryan
post Jul 19 2026, 09:39 AM
Hi Bruce. Thanks for the offer. The console on the car is also elongated, so I'm going to weld them and re-make the holes.
The shaft is also worn, so I may as well get new set from 914rubber.
I haven't torn down the drivers side yet, but assume it's in similar condition.
Bryan
- Lo-Fi Version Time is now: 19th July 2026 - 04:02 PM
