| TJB/914 |
Jul 20 2026, 10:51 AM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,502 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
Took my 914 out for a cruise yesterday & had shifting problems on the highway with no 4th or 5th gear shifts. In the garage at startup gear shifting (wobbly) was loose into all gears. On the highway 1st. 2nd & 3rd was ok but nothing into 4th. or 5th.? Need advice where to look & start for repairs. 914's are so low, getting under the 914 has issues for inspections as I get older (IMG:style_emoticons/default/headbang.gif) Tom, Looking for 914 repair shops in the Petoskey MI area is difficult. |
| brant |
Jul 20 2026, 11:01 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,233 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Start with bushings and the shifter linkage set screws
Likely a set screw came loose Or a bushing disintegrated |
| friethmiller |
Jul 20 2026, 11:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,401 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
I had this same problem where it just starts happening - where it was working fine before. I bet its the cone screw at the transmission linkage. Use blue locktite!
| brant |
Jul 20 2026, 12:17 PM
| TJB/914 |
Jul 20 2026, 12:36 PM
| FlacaProductions |
Jul 20 2026, 03:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,252 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
pull back the boot on the engine side of the firewall around the shift rod. I'm going to bet the bushing there is in pieces...
| windforfun |
Jul 20 2026, 03:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
pull back the boot on the engine side of the firewall around the shift rod. I'm going to bet the bushing there is in pieces... And you don't need to remove the rod. Get a new nylon bushing & slice the wall open at 45 degrees. Voila!!! Push it in & you're good to go. BTDT. Easy repair. |
| NARP74 |
Jul 20 2026, 03:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I built a set of wheel cradles out of scrap wood for this issue. Can get it a foot off the ground with 2x4 and 2x6 lumber, stackable and very stable. Race Ramps if you have the $$$.
| Luke M |
Jul 20 2026, 03:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,560 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Took my 914 out for a cruise yesterday & had shifting problems on the highway with no 4th or 5th gear shifts. In the garage at startup gear shifting (wobbly) was loose into all gears. On the highway 1st. 2nd & 3rd was ok but nothing into 4th. or 5th.? Need advice where to look & start for repairs. 914's are so low, getting under the 914 has issues for inspections as I get older (IMG:style_emoticons/default/headbang.gif) Tom, Looking for 914 repair shops in the Petoskey MI area is difficult. Check out Munk's Motors in Waterford, MI. : https://www.munks.com/ They fixed my old Audi Q7 when I was visiting family in MI. They also had a few 914s in the shop when I was there last. Otherwise I think McMark is in Grand Rapids? |
| emerygt350 |
Jul 20 2026, 05:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,674 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have a couple cheap drive on AutoZone ramps. That works for this cone screw job. I will put the floor jack under the driver's side as well for even more room. Hardest part is getting the boot back on the firewall. Fold the rubber back a little bit press it in place and let it flip back over the firewall lip is my trick. Some days it goes better than others.
| HLANG |
Jul 21 2026, 06:30 AM
Newbie ![]() Group: Members Posts: 6 Joined: 15-August 25 From: Germany Member No.: 28,926 Region Association: Germany |
I had the issue several times and it can have different root cause. If it got worse over time then it is most likely a bushing issue. The centre bushing btw. the cabin and the engine department is most important. If it is worn out shifting gears become gambling. But could also be the bushings in the shift gate or the plastic bushings at the gearbox itself.
If you experience a shifting issue out of the blue it is most likely no bushing issue but a connection became loose. Could be the whole shifting stick mechanism which is screwed to the chassis or any screw that is sitting on the shifting rod. In my case, I remember that 4th and 5th gear issues always disappeared after put in the second gear, opened the M8 screw between gear stick and shifting rod, aligned it and screwed it tight. In the meantime I have improved the entire shifting mechanism. Let me know if you are interested. |
Lo-Fi Version | Time is now: 21st July 2026 - 10:45 AM |
