| davep |
Jul 23 2026, 06:52 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,368 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
So the coolant level warning pops up, and I go to check the tank level. No info to be found there. So on to the cap. Waited days, and it is cold. Turn the cap about 30 deg and the tab on the bottom rim hits a stop on the neck; and it is game over: it will not turn or come off. There has to be a trick, but I cannot figure it out.
Some Benz forums mention cutting off the tab or just using brute force, but I see potential disaster with those methods. If it was turned into place it should come off with a minimum of fuss. |
Lo-Fi Version | Time is now: 24th July 2026 - 12:14 PM |
