> 914-4 Cooling fan
ndfrigi
post Aug 1 2026, 05:06 PM
Hello Teeners!
Is there a difference or interchangeable on this 2 type of fan?
Also anyone have the spacer #15 and each 3 of #6, 7 & 8?
Thank you!
post Aug 1 2026, 05:11 PM
The one with the "snout is early. Effectively interchangeable.
The (3) triplesquare ? bolts are specific.
ndfrigi
post Aug 1 2026, 05:28 PM
QUOTE(914werke @ Aug 1 2026, 04:11 PM) *
Thanks!
We are trying finish the assembly of this rebuilt 1.9 early engine with W series engine from 1971 car. Cooling fan is just temporarily installed but no spacer yet and bolts.
post Aug 1 2026, 05:38 PM
QUOTE(ndfrigi @ Aug 2 2026, 06:06 AM) *
Hello Teeners!
Thank you!
They are not all directly interchangeable. Some use longer (or shorter) fasteners. If you have too long bolts in a fan that uses shorter ones, they will tear up the seal. Also, if you need timing marks, some significant differences exist and you'll be left wondering how to time your motor (can use a dial back timing light).
Also, it's a good idea to lap the crankshaft end with the fan and ensure the woodruff key fits properly when you final fit everything together.
ndfrigi
post Aug 1 2026, 07:24 PM
Thank you also @Jack_standz also!
I think we can find head screw, washer and spring washer.
For now, we will appreciate if someone can find spacer #15 on your stash.
Thanks!
post Aug 2 2026, 05:48 AM
@914werke
' date='Aug 1 2026, 04:11 PM' post='3267179']
[/quote]
The bolts for the early fan are socket head cap screws. Hex not triple square. I says the lenght is 39mm which is not common. Mayb a 40mm will work. But it the bolts are too long they hit the crank seal.
I might have the hardware but will take a lot of searching.
post Aug 2 2026, 05:50 AM
@ndfrigi
' date='Aug 1 2026, 06:24 PM' post='3267203']
Thanks!
[/quote]
I can probably find the spacer. Note the early fan uses 39mm ling bolts. Not a common size
ndfrigi
post Aug 2 2026, 08:55 AM
[quote name='bdstone914' date='Aug 2 2026, 04:50 AM' post='3267220']
@ndfrigi
Thanks!
[/quote]
[/quote]
Thanks Bruce! I will send you a txt message for the spacer. Thanks!
post Aug 2 2026, 02:31 PM
QUOTE(Jack Standz @ Aug 1 2026, 04:38 PM) *
QUOTE
(IMG:style_emoticons/default/sunglasses.gif)
Thanks Bruce couldnt remember whether they were TS or simple hex head caps.
- Lo-Fi Version Time is now: 2nd August 2026 - 09:28 PM
