| 69146 |
Aug 3 2026, 01:42 PM
Newbie ![]() Group: Members Posts: 2 Joined: 18-August 23 From: Oldsmar Member No.: 27,532 Region Association: None |
The closest I can put the steering wheel to the housing holding the turn signal and key switch is 3/4 of an inch and it’s supposed to be about 1/8. It seems to hit on the metal tube housing the shaft. It looks like it is set too high. Any ideas on how I lower that shaft?
Thx David |
Aug 3 2026, 03:53 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,851 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Post some pics of the front and back of the wheel. Front without the horn pan because I want to see if it's an early or late wheel. Many get switched over time.
Also want to see if you have the correct plastic hub on the back. (IMG:style_emoticons/default/welcome.png) |
| 69146 |
Aug 3 2026, 04:53 PM
Post some pics of the front and back of the wheel. Front without the horn pan because I want to see if it's an early or late wheel. Many get switched over time. Also want to see if you have the correct plastic hub on the back. (IMG:style_emoticons/default/welcome.png) Thx Mark. I’m in NJ till mid August so will post when I get back to Florida. David |
Lo-Fi Version | Time is now: 3rd August 2026 - 09:31 PM |
