> Front Turn Signal, Connections
NARP74
post Aug 5 2026, 11:31 AM
I'm not there yet but soon. I remember the last time I messed with the front turn signal connections it was a frustrating exercise with colorful language involved. I'm saving this part of the rabbit hole I am in for last.
Any tips to deal with the tight, dark, need three hands operation of connecting them?
post Aug 5 2026, 12:47 PM
See diagram near the bottom of the page:
https://bowlsby.net/914/Classic/TechNotebook.htm
NARP74
post Aug 5 2026, 03:38 PM
I am mostly concerned with the how do I get my hands and fingers in there to make those connections with the rubber boot and other obstructions in the way.
Jeff, I have used your resources consistently for many years. Thank you for all of them.
post Aug 5 2026, 03:53 PM
Remove the TS bucket, make the electrical connections, mount the boot, reinstall the bucket.
post Aug 5 2026, 03:57 PM
IIRC I followed Fred when I recently did mine. cut the wires, remove the assembly, thread the wires into new rubber, get them back on the car, solder/heat shrink tubing. It's not one of the more fun projects, but if I can do it anybody can.
recalling now, I might add a couple (2) inches to the individual wires to help with the install. I like soldered connections with heat shrink tubing
NARP74
post Aug 5 2026, 04:56 PM
I will try what @JeffBowlsby said. That is basically what I did to remove the bucket for testing. Maybe that and a long pair of right angle needle nose pliers.
@930cabman , I have been up to my ears with cutting and fixing connections, I just want to climb out of this rabbit hole.
- Lo-Fi Version Time is now: 5th August 2026 - 09:29 PM
