| Spoke |
Aug 6 2026, 02:45 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,417 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I buy EP26 LED-compatible flasher relays from a well known online supplier. They are very reliable for large quantities. By large I mean 20 at a time. So far I've resold about 500 EP26's with no issues.
However EP26 is an old number reused for LED-compatible applications. On my last 20 piece order one EP-26 was included and isn't LED-compatible. EP26 is available at many FLAPS. If you buy one for LED applications make sure it says 'LED-Compatible' on the box or flasher relay. ![]() |
| worn |
Aug 6 2026, 07:18 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,640 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Thanks for the helpful advice that you always give.
| NARP74 |
Aug 6 2026, 08:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Are all of yours OK? I have 2 from you and I am going to try my LED upgrade again in the near future.
Lo-Fi Version | Time is now: 6th August 2026 - 10:55 PM |
