| 914rrr |
Aug 10 2026, 10:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,093 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
Working on my brakes and installing new soft lines in the rear. Used PB Blaster to baptise both soft line fittings to hard lines that to go the proportioning valve. Re-applied each day for a few days.
Went to remove the drivers side soft line and the fitting rounded off before the hard line snapped of just above the fitting. Had a crummy made in India flare wrench laying around that spread right away and was quickly useless. Tried again with an 11 mm Proto combo wrench on the hard line barrel and a 17 mm Indian flare on the bottom soft line. Thought I was making progress until the line broke off just above the fitting (IMG:style_emoticons/default/headbang.gif) Now, I have to replace the drivers side hard line that goes on TOP of the proportioning valve, and possibly the other twin line going to the passenger side. How do you remove THAT fitting on top without pulling the engine? I could barely get an 11 mm stubby combo wrench on it, but have almost zero room to twist it. I'm in need of solutions, ideas, old timer trick, tips if anybody has any. |
| bdstone914 |
Aug 10 2026, 11:22 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,351 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Working on my brakes and installing new soft lines in the rear. Used PB Blaster to baptise both soft line fittings to hard lines that to go the proportioning valve. Re-applied each day for a few days. Went to remove the drivers side soft line and the fitting rounded off before the hard line snapped of just above the fitting. Had a crummy made in India flare wrench laying around that spread right away and was quickly useless. Tried again with an 11 mm Proto combo wrench on the hard line barrel and a 17 mm Indian flare on the bottom soft line. Thought I was making progress until the line broke off just above the fitting (IMG:style_emoticons/default/headbang.gif) Now, I have to replace the drivers side hard line that goes on TOP of the proportioning valve, and possibly the other twin line going to the passenger side. How do you remove THAT fitting on top without pulling the engine? I could barely get an 11 mm stubby combo wrench on it, but have almost zero room to twist it. I'm in need of solutions, ideas, old timer trick, tips if anybody has any. I use a pair of Knipex plyers. Thry have jaws shaped to fit the hex. They do not kick back from the pressurevof trying to open them. Everest makes a similar pair. I descovered them in Saab tool kits. They work on hev nuts from 10-27mm. I have removed rear shock nuts with them. Attached thumbnail(s) |
| bdstone914 |
Aug 10 2026, 11:31 PM
Do you use a torch to heat the fitting. I rdid that recently. Used tust penetrent then heat. Gave it a good amount of heat then walked away. Heard a bang. The rubber hose was blown off the flex line. And the system was open on that end. Did not make sence but it happened.
Aug 10 2026, 11:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 904 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Somebody recommended these ratcheting flare wrenches, but haven't pulled the trigger yet to buy them, so can't offer any personal experience with them:
https://www.amazon.com/gp/product/B0CCZTQX43?psc=1&th=1 Amazon.com sells them as individual wrenches too, if you're not up to get the whole set. Here's a set with flexible heads that might help with that stubborn one on top of the brake pressure regulator. https://www.amazon.com/PRIDE-CRAFT-Flex-hea...164&sr=8-11 |
| porschetub |
Aug 11 2026, 12:12 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,154 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Working on my brakes and installing new soft lines in the rear. Used PB Blaster to baptise both soft line fittings to hard lines that to go the proportioning valve. Re-applied each day for a few days. Went to remove the drivers side soft line and the fitting rounded off before the hard line snapped of just above the fitting. Had a crummy made in India flare wrench laying around that spread right away and was quickly useless. Tried again with an 11 mm Proto combo wrench on the hard line barrel and a 17 mm Indian flare on the bottom soft line. Thought I was making progress until the line broke off just above the fitting (IMG:style_emoticons/default/headbang.gif) Now, I have to replace the drivers side hard line that goes on TOP of the proportioning valve, and possibly the other twin line going to the passenger side. How do you remove THAT fitting on top without pulling the engine? I could barely get an 11 mm stubby combo wrench on it, but have almost zero room to twist it. I'm in need of solutions, ideas, old timer trick, tips if anybody has any. Bugger that's a whole world of trouble ,buy/loan a flaring tool and use VW jointers which are used on 80s and 90s Golfs ,they are normally used on the engine side of the firewall ,chop them out of a pick and pull wreak. Use a bit of heat on the bad fitting and get yourself some decent brake line spanners ,good luck ,cheers. |
Lo-Fi Version | Time is now: 11th August 2026 - 04:26 AM |
