| jmargush |
Aug 18 2026, 07:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 502 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I have read several of the hot start (starter related not fuel) and have mixed opinions on the fix as the threads exhibit as well.
I have had the car on the road for 24 years and never had a problem with the stock setup. then the other week at an autox I shut the car off in grid and it wouldn't turn over enough to start. Let it cool down and it started fine. Did some reading when I got home. At this point I have cleaned all the connections except the one on the transmission. Cables look good other than the one going to the alternator 9it have some corrosion around the terminal on the starter. Ran it for 10 or so minutes the other day shut it off let it sit for a few minutes it started but seemed a bit on the slow side shut it off and tried again much slower but did eventually start did it again and it was even slower next time it wouldn't even turn over. While doing this I was checking voltage form the ignition wire terminal on the solenoid to negative on battery. it is down to about volts when trying to start. so would you say this is confirmation of ignition switch or need for the additional solenoid or might the battery be weak? |
| emerygt350 |
Aug 19 2026, 04:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,704 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I have read several of the hot start (starter related not fuel) and have mixed opinions on the fix as the threads exhibit as well. I have had the car on the road for 24 years and never had a problem with the stock setup. then the other week at an autox I shut the car off in grid and it wouldn't turn over enough to start. Let it cool down and it started fine. Did some reading when I got home. At this point I have cleaned all the connections except the one on the transmission. Cables look good other than the one going to the alternator 9it have some corrosion around the terminal on the starter. Ran it for 10 or so minutes the other day shut it off let it sit for a few minutes it started but seemed a bit on the slow side shut it off and tried again much slower but did eventually start did it again and it was even slower next time it wouldn't even turn over. While doing this I was checking voltage form the ignition wire terminal on the solenoid to negative on battery. it is down to about volts when trying to start. so would you say this is confirmation of ignition switch or need for the additional solenoid or might the battery be weak? I don't think this is the solenoid issue. That just stops the starter from doing anything at all. It can be associated with a problem like yours because of the low voltage but in your case it really appears to be a ground or battery issue. You could add an extra ground from the negative battery terminal to the fan shroud (use a nice batt. Cable from a flaps that has two loops instead of the big lead terminal hookup ). There is a nice attachment point just to the right of the distributor. First I would clean the battery ground to the body, the connection from the battery to the starter, and the transmission ground. How old is your battery? |
Lo-Fi Version | Time is now: 19th August 2026 - 12:31 PM |
