| nivekdodge |
Aug 27 2026, 11:00 AM
Member ![]() ![]() Group: Members Posts: 340 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
Guys,
I have two fan wheels one is labeled with the 113 part number and doesn’t have a timing mark. The other is not labeled with the part number, but has the timing mark which is the correct one. |
| brant |
Aug 27 2026, 12:40 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,258 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Both can fit/interchange as long as you match the mounting hardware for early and late style
The timing marks are different for different size motors No way for us to tell if your marked fan has the correct timing marks for your motor Believe there is a template or photo on this site you will need to use to examine your marked fan |
| brant |
Aug 27 2026, 12:42 PM
You can put your motor onto tdc and see how the mark lines up when you mount it, or correct the mark if it’s the wrong one
Lo-Fi Version | Time is now: 27th August 2026 - 08:21 PM |
