| Speedo |
Sep 6 2026, 08:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains
So I have replace all of my targa top seals and rubber both on the car, and targa top. Front fits very well...nice and snug. Rear latches don't seem to be able to extend far enough to capture the pin on the top. I re-built the latches, so I don't see where I'm losing length. Stiff new rubber? I'm at a loss and open to suggestions.
Sep 6 2026, 09:39 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,896 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Can you leave the top upside down in the sun and then give it a try once things heat up a bit.
| Speedo |
Sep 6 2026, 10:02 AM
Yes, I will get it into the sun. But the contact point between the top of the targabar (metal) and the bottom shoe (metal) of the top isn't rubber. It's metal on metal. I was wondering if my latch is hooking up and not getting full extension? I should measure the height of the inside hoop of the latch at full extension and compare it with someone else's latch?
Can you leave the top upside down in the sun and then give it a try once things heat up a bit. |
| bdstone914 |
Sep 6 2026, 10:01 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,373 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Speedo
date='Sep 6 2026, 09:02 AM' post='3270893'] Yes, I will get it into the sun. But the contact point between the top of the targabar (metal) and the bottom shoe (metal) of the top isn't rubber. It's metal on metal. I was wondering if my latch is hooking up and not getting full extension? I should measure the height of the inside hoop of the latch at full extension and compare it with someone else's latch? [quote name='mepstein' post='3270892' date='Sep 6 2026, 07:39 AM'] Can you leave the top upside down in the sun and then give it a try once things heat up a bit. [/quote] [/quote] New seals can be the issue. Try shimming down rubber blocks on the targa top by putting a washer under each bolt hole. pictures would help too |
Lo-Fi Version | Time is now: 7th September 2026 - 06:32 AM |
