| TonyH |
Sep 9 2026, 10:37 AM
Member ![]() ![]() Group: Members Posts: 77 Joined: 30-January 22 From: Normandy, France Member No.: 26,296 Region Association: France |
Good afternoon everyone,
It's getting cooler now autumn is here in Europe. A question, what is the best form of adhesive/system for sticking the interior mirror back on the windscreen on my 914? She has spent most of her life in California and I think the UV from the sun must have finally won the battle because the mirror just fell off! In the past there has been loads of "wonder products" for sticking mirrors back on screens, but non of them worked for very long. Some years ago I fitted a high level brake light on the interior of my VW Eurovan and that is still on there, but part of the kit were two black patches for the outside, which must have helped to reduce the UV. I noticed that on modern vehicles they have a black printed area on the screen which obviously helps protect the adhesive. Any help or suggestion would be gratefully received. Thanks in advance. Tony |
Sep 9 2026, 11:11 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,902 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I’ve used the high strength permatex adhesive on a bunch of customer cars. Available at most auto parts stores. Use some tape around the mounting point so you mark the location once you clean off the old adhesive.
| Dlee6205 |
Sep 9 2026, 11:25 AM
Member ![]() ![]() Group: Members Posts: 103 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
For 914s I use an adhesive pad (double sided VHB tape) for installation rather than glue.
| dr914@autoatlanta.com |
Sep 9 2026, 11:30 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,243 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
factory mirror patch, it also insulates the mirror to keep it from vibrating as much
Good afternoon everyone, It's getting cooler now autumn is here in Europe. A question, what is the best form of adhesive/system for sticking the interior mirror back on the windscreen on my 914? She has spent most of her life in California and I think the UV from the sun must have finally won the battle because the mirror just fell off! In the past there has been loads of "wonder products" for sticking mirrors back on screens, but non of them worked for very long. Some years ago I fitted a high level brake light on the interior of my VW Eurovan and that is still on there, but part of the kit were two black patches for the outside, which must have helped to reduce the UV. I noticed that on modern vehicles they have a black printed area on the screen which obviously helps protect the adhesive. Any help or suggestion would be gratefully received. Thanks in advance. Tony |
| dtmehall |
Sep 9 2026, 11:38 AM
Member ![]() ![]() Group: Members Posts: 358 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
I’ve used the high strength permatex adhesive on a bunch of customer cars. Available at most auto parts stores. Use some tape around the mounting point so you mark the location once you clean off the old adhesive. (IMG:style_emoticons/default/agree.gif) with mepstein |
| porschetub |
Sep 9 2026, 02:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,166 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
For 914s I use an adhesive pad (double sided VHB tape) for installation rather than glue. (IMG:style_emoticons/default/agree.gif) ,using the old adhesive mark ensures it go's back where it should be,I marked my on the outside of the screen with painters' tape . Wiped the inside with acetone several times till spotless, these pads stick really well and straight away , cheers. |
| TonyH |
Sep 10 2026, 05:12 AM
For 914s I use an adhesive pad (double sided VHB tape) for installation rather than glue. (IMG:style_emoticons/default/agree.gif) ,using the old adhesive mark ensures it go's back where it should be,I marked my on the outside of the screen with painters' tape . Wiped the inside with acetone several times till spotless, these pads stick really well and straight away , cheers. Very many thanks to everyone for your prompt help. It is much appreciated. Tony |
Lo-Fi Version | Time is now: 10th September 2026 - 08:30 AM |
