| Joe Simon |
Sep 10 2026, 01:11 PM
Newbie ![]() Group: Members Posts: 14 Joined: 7-May 19 From: New Jersey Member No.: 23,102 Region Association: None |
Aluminum 911S/930 front Calibers and associated hardware. Includes Stainless Steel supply lines, variable proportioning valve and brake pads,
Will fit factory 914 existing brake assembly. Email: joesimon1@optonline.net $850 Plus Freight ![]() |
Sep 10 2026, 01:22 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,903 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It will not fit stock 914 or 914-6 front struts. Only later 3 1/2” struts.
Sep 10 2026, 04:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 916 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
We are running 911 S calipers on our '74, but we are also running 911 struts with the 3.5 inch spacing on the mounting ears (and 911 everything else, like: cross member, vented rotors, hubs, strut inserts and anti sway bar). |
| bdstone914 |
Sep 10 2026, 04:47 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
QUOTE @Joe Simon[/b] date='Sep 10 2026, 12:11 PM' post='3271369'] Aluminum 911S/930 front Calibers and associated hardware. Includes Stainless Steel supply lines, variable proportioning valve and brake pads, Will fit factory 914 existing brake assembly. Email: joesimon1@optonline.net $850 Plus Freight ![]() Are they original Ate calipers or aftermarket ? |
Lo-Fi Version | Time is now: 11th September 2026 - 10:16 AM |
