> Six convertion gearbox
DavidSweden
post Sep 19 2026, 01:16 PM
Region Association: Scandinavia
Hello,
I’ve just rebuilt a 1971 2.2T engine, with the intention of installing it in my 914.
As I understand it, it should be possible to mate the existing side-shift gearbox to the 2.2T engine by using an early flywheel, while retaining the existing 914 clutch.
Is this correct?
Thanks in advance
SirAndy
post Sep 19 2026, 02:03 PM
Resident German
That should be possible.
I'm running a stock 901 side-shifter behind my 3.6L /6 (Although not with a stock clutch).
mlindner
post Sep 19 2026, 02:21 PM
Yes, I running a 901 side shift with short gears from a 2.2 S with PMOs and Ben's headers. Love it.Attached Image
Retroracer
post Sep 19 2026, 04:42 PM
Yes, that is the exact combination I have in my car. I recall that I used the 914 pressure plate and clutch, but I'd have to check.
BTW - Don't neglect the main shaft support bearing and washer that sits in the flywheel / crank area - suggest renew that and the clutch throwout bearing at the same time. Also the (nylon?) pivot bushing, as these crumble over time.
- Tony
post Sep 19 2026, 04:48 PM
QUOTE(DavidSweden @ Sep 20 2026, 07:16 AM) *
Hello,
Is this correct?
Thanks in advance
Have the same engine ,used Saches NOS pressure plate and disk way before they got rather expensive ,a very straight forward conversion IMO.
The 215mm clutch handles extra h.p. no problem well over what the 2.2 T can deliver as my research indicated .
Cheers .
post Sep 19 2026, 05:21 PM
QUOTE(Retroracer @ Sep 20 2026, 10:42 AM) *
- Tony
(IMG:style_emoticons/default/agree.gif) any wear parts as Tony mentioned above ,I would add input shaft seal also ,mine was dry but leaked not long after I had been driving it for a while .
I think its worth so you don't have my issue and learn from it (IMG:style_emoticons/default/chair.gif) .
Cheers.
DavidSweden
post Sep 20 2026, 01:50 AM
Thanks for the feedback.
Much appreciated.
1 Members: erwan914
- Lo-Fi Version Time is now: 20th September 2026 - 04:10 AM
