| friethmiller |
Sep 20 2026, 08:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,531 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
| IronHillRestorations |
Sep 20 2026, 09:11 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,956 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
You’re probably going to have to get the pulley hotter. I’d use a gear puller and heat the center of the pulley with a torch. I’d start by soaking it for a couple days with Deep Creep.
| 76-914 |
Sep 21 2026, 09:02 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,966 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
By Juice do you mean WD40? If so try this. Heat then squirt with water. Several cycles of this will usually render a result. You want to cool it quickly and completely. Shock cooling helps with the expansion/contraction. (IMG:style_emoticons/default/beerchug.gif)
Sep 21 2026, 09:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 925 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Have used gear pullers before (2-jaw), even steering wheel pullers, whatever is available. To not damage the pulley, have even used a bearing separator/splitter in combination with a puller.
If you want or "need" another tool, here's something for your toolbox: https://www.amazon.com/VEVOR-Bearing-14-Pie...B0CX1BV6QD?th=1 Of course there's always a BFH. (IMG:style_emoticons/default/biggrin.gif) Best wishes for getting it off safely and undamaged. |
| friethmiller |
Sep 21 2026, 09:30 AM
Thanks guys! I'll keep at it. I've got about 14 different things going on between the two cars at the moment. (IMG:style_emoticons/default/biggrin.gif)
WD40 = juice |
Lo-Fi Version | Time is now: 21st September 2026 - 11:34 AM |
