| 914werke |
Sep 22 2026, 09:19 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,756 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
| Shivers |
Sep 23 2026, 06:04 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,604 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
The whole is greater than the sum of its parts. -Aristotle. (IMG:style_emoticons/default/biggrin.gif)
| 914Sixer |
Sep 23 2026, 06:23 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,572 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Why did they not use 2.0L 3 bolt heads?
Sep 23 2026, 06:42 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It’s AA.
| carr914 |
Sep 23 2026, 07:28 AM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 134,827 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Sep 23 2026, 07:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,078 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I hope to hit the lottery too. (IMG:style_emoticons/default/shades.gif)
| infraredcalvin |
Sep 23 2026, 08:36 AM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
| Ninja |
Sep 23 2026, 09:03 AM
Member ![]() ![]() Group: Members Posts: 315 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
The prices that T4s are going for is astronomical!
At 20K I'd be able to turbo a LS series engine and achieve 4 figure power numbers. On a K24 at 20K I'd be 350hp NA OR 600+hp boosted. I could buy a brand new LS3 crate puppy with the electronics (and a warranty!) for less than 20K. Might be able to include the Boxster 6 speed too. And those setups would be conservative... Just WOW on sticker shock! |
| friethmiller |
Sep 23 2026, 09:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,535 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
... and stock push rods. This can't be that hot of a setup.
| 76-914 |
Sep 23 2026, 09:34 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,967 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
But wait! There are 2 available at that price! (IMG:style_emoticons/default/barf.gif) I could buy 15 Subaru 6's for that kind of $$$. Nuts.
| sixnotfour |
Sep 23 2026, 09:52 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,371 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Porsche 914 2.0 Djet motor for sale…
Len Hoffman machined AA heads (914 world group buy) Raby 9590 cam 2056 cc 123 distributer GA block Engine work and assembly by Jorge at European Auto. Tuned Djet with Tangerine Racing modified MPS. New wiring harness Powder coated 2.0 engine tins Complete broke in (1000 miles) ready to run Engine, flywheel, clutch, ECU, fuel pump. $9k Also have stainless steel heat exchangers and Ben Mcfarland GT muffler at additional$ https://www.facebook.com/100000290693279/vi...905425626791388 |
| Ninja |
Sep 23 2026, 10:28 AM
That's actually a good deal!
Bet he'd throw in an alternator as well... New wiring harness, good stuff, fully broken in and debugged. That is what a RTG (ready to go) engine SHOULD be priced at. |
| JamesM |
Sep 23 2026, 10:44 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,310 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Not to (IMG:style_emoticons/default/stromberg.gif) on anyone, but seeing that thermostat on there I immediately lost all faith in the knowledge of whoever put that together.... especially for 21k
For 21k you should have a running turnkey motor with ZERO red flags, some documentation on specs (that should be massively upgraded) and maybe dyno numbers. I see a motor of completely unknown specs (other than stock pushrods) that has never fired, with a thermostat you should NEVER use on a type 4, non 2.0 heads, and an early style cooling fan that now requires balancing. Maybe it is a 21k motor? but i dont see how you would ever sell one with a listing like this. |
| 914werke |
Sep 23 2026, 10:58 AM
At the risk of (IMG:style_emoticons/default/stirthepot.gif) I look at such an offering along the lines of Jakes efforts.
Promote promote promote !!! Set a high bar for access Make unsubstantiated claims Never provide full specifications or details. (IMG:style_emoticons/default/hide.gif) |
| Montreal914 |
Sep 23 2026, 12:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,199 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
But you get to brag your engine was built by a PhD in 914.
That’s quite a claim! (IMG:style_emoticons/default/laugh.gif) …yet it come with no warranty, only a thermostat that could ruin your engine. Seems like s no brainer to me. (IMG:style_emoticons/default/chowtime.gif) |
| flxzcat |
Sep 23 2026, 01:21 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 13-June 11 From: Lake Forest, So. Cal. Member No.: 13,188 Region Association: Southern California |
Lo-Fi Version | Time is now: 23rd September 2026 - 04:04 PM |
