| orangecrate |
Sep 27 2026, 01:52 PM
Member ![]() ![]() Group: Members Posts: 187 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
My hazard switch is wonky . I'm looking at some vw stuff online that has the part# but slightly differet configuration. Anyone tried this or know an interchangeable part? This is maddening. Thanks. It's a 72.
Sep 27 2026, 02:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,843 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
My hazard switch is wonky . I'm looking at some vw stuff online that has the part# but slightly differet configuration. Anyone tried this or know an interchangeable part? This is maddening. Thanks. It's a 72. I'd bet a VW part would either plug right in or with little modification |
| JeffBowlsby |
Sep 27 2026, 02:09 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,360 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Look for a used original, there should be many available. They rarely fail.
| wonkipop |
Sep 27 2026, 03:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,730 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
My hazard switch is wonky . I'm looking at some vw stuff online that has the part# but slightly differet configuration. Anyone tried this or know an interchangeable part? This is maddening. Thanks. It's a 72. by different configuration do you mean the central colored bit with the symbol is different. if so - then its just a matter of either looking around enough to find the right one, or just flipping out that central plastic bit with the symbol and putting in your old plastic bit from your wonky switch. the euro cars had a different symbol in the switch than the USA cars. a lot of the aftermarket repro switches have the euro symbol in them. same goes for cig lighters. a lot of the new repro replacement switches have the later cig lighters used in the Golf with a cig and smoke swirl. but if you look around you can find the older "ronson" lighter style symbol. usually from european VW parts shops. |
| orangecrate |
Sep 27 2026, 06:02 PM
| JeffBowlsby |
Sep 27 2026, 10:13 PM
Post the part number you need, there are two different switches for the 914:
https://bowlsby.net/914/WiringHarnesses/doc...ashSwitches.pdf |
Lo-Fi Version | Time is now: 27th September 2026 - 11:42 PM |
