> Instrument lights ground point
Cvrguy
post Oct 1 2026, 01:15 PM
I had all of the instrument lights go out on me recently. Is there a single ground point for them? If so, where is it? I checked the defrost light wire aft of the shifter. That's not the problem.
post Oct 1 2026, 01:42 PM
Probably the ground behind the fuse panel, drivers side. You might also have a dash light subharness that could be disconnected, its not very long, is behind the dash gauges, look for any of the black/blue striped wires to find the common single connector to the main chassis harness.
FlacaProductions
post Oct 1 2026, 01:52 PM
the common black/blue striped line was the one i was going to suggest - it runs thru all the dash lights - if there is a gap "early" in the chain, they all go
- Lo-Fi Version Time is now: 2nd October 2026 - 03:09 AM
