> Crank engine to build up oil pressure
burlybryan
post Oct 10 2026, 02:30 PM
I'm wrapping up installing my rebuilt 2 liter with djet. I want to crank it to circulate some oil without fuel. Can i just pull the fuel pump relay and turn on the ignition or will that disable more than the pump?
Thanks.
post Oct 10 2026, 02:38 PM
I would also remove the spark plugs
post Oct 10 2026, 02:44 PM
Or you could pull the fuse on the board. It's the one closer to the rear of the car.
- Lo-Fi Version Time is now: 11th October 2026 - 11:03 AM
