> Gas prices are too high! What about E85?, Anyone have experience running E85 in their 914?
post Oct 11 2026, 02:35 PM
As you all know, gas (and diesel) prices are on a rampage and are the highest we personally have ever seen them. Maybe using E85 is a viable work around?
Take a look at the embedded table showing current gas prices and how they've skyrocketed the last year in the Bay Area (probably similar experiences elsewhere). Then last night we went to the store and E85 was selling at only $3.39.
Anyone have experience running E85 in their 914? A simple jet change on a carbureted 914? Just an adjustment to the tune in a FI 914? Fuel pump change needed? (We already have alcohol ready fuel lines)
Having never run E85, looking for thoughts from the experts here. TIA
post Oct 11 2026, 03:57 PM
D-jet forggeda’ bout’ it.
With a mega squirt it’s possible but you’re going to need a flex fuel sensor to know what you’re running as E85 ethanol content is pretty variable depending on Regionality and seasonal mix. Ethanol content varies the stoichiometric mix and would need to run closed loop.
I suppose if you could get ethanol race fuel with a consistent ethanol content you could tune a carb for it but where you going to get that fuel and what would be the point for a street vehicle.
GregAmy
post Oct 11 2026, 06:19 PM
As noted above, even with MS you'd have to do a totally different tune and a sensor to swap to the other tune.
Unless you're driving your 914 15,000 miles per year it really doesn't make economical sense (the cost of adding a sensor and the dyno time to tune it could buy a lot of fuel...)
Osnabruck914
post Oct 11 2026, 07:16 PM
Frankly, owning and operating a 914 is a luxury to begin with. Spending a little more on the proper fuel (non-ethanol in my case) is just part of owning that luxury. If money was a concern to feed the car with the right fuel, I would ditch the luxury. My opinion and nothing else implied.
Osnbruck914
Chris914n6
post Oct 11 2026, 07:56 PM
Jackstands are my life.
NO. Not even a viable option. E10 already causes problems.
dtmehall
post Oct 11 2026, 08:05 PM
(IMG:style_emoticons/default/agree.gif) with Osnabruck914
bkrantz
post Oct 11 2026, 08:37 PM
The cool thing is that even at past lows gas prices in California were higher than the current US average.
post Oct 11 2026, 10:33 PM
QUOTE(Chris914n6 @ Oct 12 2026, 02:56 PM) *
(IMG:style_emoticons/default/agree.gif) , learned my lesson the hard way ,we don't have non ethanol in my country so if you are storing a car or infrequent use be prepared for issues unless you drain this all out.
Oh and fuel hose will suffer ,only use Gates barricade now and so far so good, other so called ethanol rated didn't cut it.
Cheers.
brant
post Oct 12 2026, 07:47 AM
bad idea.
would require a modern tunable injection.
short shelf life, less MPG
good for a tuned modern turbo motor
post Oct 12 2026, 08:04 AM
Let’s try this: Anyone have any actual experience running E85 in their 914 or any other carbureted vehicle? TIA for your thoughts.
Based on the above responses and a little more research, it seems the alcohol content in E85 can vary from around 50% to 85%, depending on the season. That does seem to be a difficult issue if you’re running carbs where changing jets on the fly is much more a problem than having a sensor that can tell you the % for a FI system.
So, in real life use, can E85 work for running carbs on the street?
JamesM
post Oct 12 2026, 08:23 AM
Caretaker of 914s - Master of Fuel Injection
QUOTE(Jack Standz @ Oct 11 2026, 12:35 PM) *
I just got back from Austin Texas, Regular there was only 3.49 (vs ~5/gal here in Utah)
This is the exact reason I have been driving my 914 more, with the current Megasquirt setup/tune I have on it I get close to 40mpg vs the ~20mpg I get out of my BMW.
Never known anyone that has run E85 in an NA car, only turbo guys as it allows them to run more boost.
I would be curious to know what impacts it has on a NA air cooled car as far as heads temps, mileage, power, etc.
Not sure there would be much savings either way though, E85 takes 30-40% more volume of fuel than gas for the same air charge to achieve stoichiometric and contains less energy per volume so what you save in per gallon costs you may wind up loosing anyways as you have to burn a lot more of it for the same results.
post Oct 12 2026, 08:25 AM
You will also need bigger fuel lines. Your fuel mileage will be less
post Oct 12 2026, 09:23 AM
QUOTE(Jack Standz @ Oct 12 2026, 10:04 AM) *
Yes. No.
You can convert a gasoline engine to run on wood. Yes wood. Lookup wood gasification if you’re bored.
Early tractors ran dual fuel. Had to start on gasoline then switched to Kerosene when the engine became hot enough. Dual fuel tractors had to run lower compression ratio to make this possible.
The first Mercedes ran on Ligroin.
You can run on almost anything. But the question is at what price both in terms of loss of performance, cost to convert, and cost to operate.
I’m no fan of battery conversions but that would make more economic sense than E85.
GregAmy
post Oct 12 2026, 10:22 AM
QUOTE(Superhawk996 @ Oct 12 2026, 10:23 AM) *
I learned a new word today...
mgp4591
post Oct 12 2026, 10:44 AM
QUOTE(GregAmy @ Oct 12 2026, 10:22 AM) *
Sounds painful, doesn't it?
eric914
post Oct 12 2026, 11:06 AM
Don's forget that Ethanol has 33% less energy per gallon that pure gas. If your E85 is 85% ethanol (it could be less) the equivalent price compared to pure gas would be $4.34
I have a friend who has tuned his Ford F150 Raptor to run on E50. He uses a test kit to measure the actual ethanol content of E85 when he fills up and then adjusts the % of gas he adds to end up at a 50% Ethanol / Gas mix.
4 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th October 2026 - 01:12 PM
