> Macan GTS motor in a 914?
ConeDodger
post Oct 15 2026, 09:55 PM
Apex killer!
Maybe Marty can weigh in on this. The 3.0 liter twin turbo motor in my Macan GTS is so freaking amazing, I wonder if it would fit in a 914? (IMG:style_emoticons/default/confused24.gif)
SirAndy
post Oct 15 2026, 10:56 PM
Resident German
Anything will fit. All it takes is money.
Having said that, there are a few engines out there i'm still ogling.
But my targets are all air-cooled.
(IMG:style_emoticons/default/biggrin.gif)
tygaboy
post Oct 15 2026, 11:04 PM
I looked into this and went so far as separating the starter ring gear from a Macan flywheel. Talked with Kennedy about an adapter. The issue is you need to convert the engine to dry sump as the Macan sump is quite deep. I even talked with Marty about his set up.
As @SirAndy points out, it's doable, but I opted for something simpler... (IMG:style_emoticons/default/happy11.gif)
If you decide to go this way, let me know. I have a ring gear I don't need.
Maltese Falcon
post Oct 16 2026, 02:25 AM
Only 3) things needed; Torch, Hammer, Machine shop (IMG:style_emoticons/default/smile.gif)
The h2o cooled Macan, Cayenne engines have great dry sump oiling systems, however the system is internally placed in the 'Pan. This creates a very deep and low hanging oil pan...if you plan to build an 'Offroad 914 jacked up >>you will probably not scrape the oil pan, it is approx 9" lower than the centerline of crankshaft.
Custom cnc machined aluminum low-profile oil-pan, combined with an external dry sump pump is the solution.
Also the requirement for a cnc aluminum adapter plate for use with a manual transaxle, as these engines do not resemble a standard VW/ or Porsche bolt pattern for direct interfit. The OE crank trigger signals are located back in the starter-ring area...so to simplify your ecu management > a new trigger should be adapted to the front of the crank area.
Front & custom dry sump pan, dry sump pump, crank trigger wheel.
Note the centerline distance of the crank pulley-to-bottom of pan, it's "911/ 9146 like" with ample ground clearance.
Maltese Falcon
post Oct 16 2026, 02:32 AM
Aluminum adapter plate is approx 1" thick, which will move your (choice of) transaxle rearwards by 1".
The wide 'V design of ghe v6/ v8 engine will clear the 914 unibody, and the trailing arm mounting points. The large 'Wilson intake plenum obviously does NOT fit under the 914 grill, but the OE plastic intake manifold will clear.
Maltese Falcon
post Oct 16 2026, 02:39 AM
You can source a good clutch pressure plate combo from a Tilton dealer ; like Aasco in OC, Ca.
Aasco also stocks and sells PMNA hydraulic t/o/b.
post Oct 16 2026, 12:10 PM
QUOTE(ConeDodger @ Oct 16 2026, 10:55 AM) *
Rob, I know exactly what you mean. We are big fans of the Cayenne S motor (not the 6 cylinder or twin turbo Cayenne motors). Have thought about what it would take to put one in the '72 914. Then realized quickly it's not an easy or really reasonable swap. Let someone else do it. (IMG:style_emoticons/default/biggrin.gif)
Also big fan of the 32 valve quad cam 928 motors starting in 1985+. As you know, a 928 (16 valve motor) has been swapped into a 914. Our solution is going to be trying to put it in a different vehicle.
So, great motors, just find a different car to swap into??
1 Members: Nana's_914
- Lo-Fi Version Time is now: 16th October 2026 - 04:50 PM
