| Luke M |
Oct 19 2026, 03:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I took my 73 steer column apart to replace the bearings, ignition switch, and to install the electric washer pump switch. I removed the turn signal and washer stalk and this little brass part fell out. I have no clue where it came from nor see where it would even go. I've had a few columns apart before and do not recall this ever being a problem. Anyone have a clue?? (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) Attached image(s)
| Shivers |
Oct 19 2026, 03:48 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,669 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I took my 73 steer column apart to replace the bearings, ignition switch, and to install the electric washer pump switch. I removed the turn signal and washer stalk and this little brass part fell out. I have no clue where it came from nor see where it would even go. I've had a few columns apart before and do not recall this ever being a problem. Anyone have a clue?? (IMG:style_emoticons/default/confused24.gif) I just had to find the thread. where it goes |
Lo-Fi Version | Time is now: 19th October 2026 - 09:59 PM |
