| ConeDodger |
Oct 23 2026, 09:19 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,628 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so…
What do I need? Currently running the JWest shifter for the 901. |
| Steve |
Oct 23 2026, 10:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,104 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so… What do I need? Currently running the JWest shifter for the 901. Been there done that... I reached out to JWest and converted my 901 Rennshift to a 915 Rennshift. I originally made my own shift rod with two Apex joints. PMS said it was too wimpy, so I ended up with their shift rod. I am running the Martin Bott 916 kit. If your kit is a wevo, it is a totally different animal. It is a lot of work but worth it. Check out this link for pictures of the home made shift rods. Otherwise pay the bucks and buy all the plug and play stuff from PMS. http://www.914world.com/bbs2/index.php?showtopic=102988 This page is from one of the PMS builds, mine is identical, except for MSDS 1 3/4" headers for my 3.6. https://patrickmotorsports.com/blogs/news/1972-914-tangerine |
| SirAndy |
Oct 23 2026, 10:12 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,550 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Many moons ago i helped Brad adding a custom cable shift solution to a 915 in a 914.
It worked surprisingly well and costs a fraction of the side-shift kits available. I have a 915 that was meant to go with the 3.6L engine but i never got around using it. The plan was to do the same thing and go cable shift. (IMG:style_emoticons/default/idea.gif) |
Oct 23 2026, 10:22 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,950 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I’m building two Martin Bott 916 kits right now. I figured I’d get to the shift rod issue when I get done the trans.
I need to sell my 915 with the Wevo kit. |
| ConeDodger |
Oct 23 2026, 10:23 AM
Many moons ago i helped Brad adding a custom cable shift solution to a 915 in a 914. It worked surprisingly well and costs a fraction of the side-shift kits available. I have a 915 that was meant to go with the 3.6L engine but i never got around using it. The plan was to do the same thing and go cable shift. (IMG:style_emoticons/default/idea.gif) Weird to think that there are maybe only a handful of us that know who you mean when you say you helped “Brad.” (IMG:style_emoticons/default/rolleyes.gif) Our plan (Mark) was a cable shifter set up. Glad to hear it worked well. |
| Steve |
Oct 23 2026, 10:30 AM
I am happy with my 915/916 conversion. It also has the cool 916 history to it, but money wise it seems a Boxster S or Cayman S six speed would make more sense.
The 915 is a little balky to shift, but you get used to it. https://forums.pelicanparts.com/porsche-911...ed-engines.html |
| Luke M |
Oct 23 2026, 11:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,618 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so… What do I need? Currently running the JWest shifter for the 901. Been there done that... I reached out to JWest and converted my 901 Rennshift to a 915 Rennshift. I originally made my own shift rod with two Apex joints. PMS said it was too wimpy, so I ended up with their shift rod. I am running the Martin Bott 916 kit. If your kit is a wevo, it is a totally different animal. It is a lot of work but worth it. Check out this link for pictures of the home made shift rods. Otherwise pay the bucks and buy all the plug and play stuff from PMS. http://www.914world.com/bbs2/index.php?showtopic=102988 This page is from one of the PMS builds, mine is identical, except for MSDS 1 3/4" headers for my 3.6. https://patrickmotorsports.com/blogs/news/1972-914-tangerine I have the same setup as Steve. Carrera 915 with the Bott 916 kit and all of the PMS shift linkage. I'm going to use the JWest shifter as well. All still waiting to get installed so no real world experience on how it all works. PMS did the Bott 916 conversion several years ago. It was not cheap then so I can't imagine what it would cost today. |
Oct 23 2026, 12:54 PM
Ok, for those of you who have put a 915 in your 914, what are the linkage requirements? Does it just magically connect to the same 901 linkage? I didn’t think so… What do I need? Currently running the JWest shifter for the 901. Been there done that... I reached out to JWest and converted my 901 Rennshift to a 915 Rennshift. I originally made my own shift rod with two Apex joints. PMS said it was too wimpy, so I ended up with their shift rod. I am running the Martin Bott 916 kit. If your kit is a wevo, it is a totally different animal. It is a lot of work but worth it. Check out this link for pictures of the home made shift rods. Otherwise pay the bucks and buy all the plug and play stuff from PMS. http://www.914world.com/bbs2/index.php?showtopic=102988 This page is from one of the PMS builds, mine is identical, except for MSDS 1 3/4" headers for my 3.6. https://patrickmotorsports.com/blogs/news/1972-914-tangerine I have the same setup as Steve. Carrera 915 with the Bott 916 kit and all of the PMS shift linkage. I'm going to use the JWest shifter as well. All still waiting to get installed so no real world experience on how it all works. PMS did the Bott 916 conversion several years ago. It was not cheap then so I can't imagine what it would cost today. The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car. |
| SirAndy |
Oct 23 2026, 01:37 PM
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car. (IMG:style_emoticons/default/blink.gif) |
Oct 23 2026, 02:01 PM
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car. (IMG:style_emoticons/default/blink.gif) Round numbers. I’m probably a bit less. PMS is probably more. There’s no way to do it cheap. Just like when we bought engines years ago for single digits. I did just buy the Martin Bott kits so they are real world numbers, not just make believe. Martin won’t ship the kit until you send him the core parts from the 915 trans so it’s a bit of a commitment to get started. |
| SirAndy |
Oct 23 2026, 03:30 PM
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car. (IMG:style_emoticons/default/blink.gif) Round numbers. I’m probably a bit less. PMS is probably more. There’s no way to do it cheap. Just like when we bought engines years ago for single digits. I did just buy the Martin Bott kits so they are real world numbers, not just make believe. Martin won’t ship the kit until you send him the core parts from the 915 trans so it’s a bit of a commitment to get started. I don't doubt the numbers, just can't believe what this stuff costs these days. (IMG:style_emoticons/default/wacko.gif) |
| Steve |
Oct 23 2026, 03:34 PM
The kit cost $5500-6k depending on which one you need. Add $1k for tarrifs. A core 915 trans is about $4k and then 5-7k to rebuild and install the kit. Another 2k for LSD and $x to install in the car. (IMG:style_emoticons/default/blink.gif) Round numbers. I’m probably a bit less. PMS is probably more. There’s no way to do it cheap. Just like when we bought engines years ago for single digits. I did just buy the Martin Bott kits so they are real world numbers, not just make believe. Martin won’t ship the kit until you send him the core parts from the 915 trans so it’s a bit of a commitment to get started. I don't doubt the numbers, just can't believe what this stuff costs these days. (IMG:style_emoticons/default/wacko.gif) I’m glad I did the 916 trans when I did. I probably have around $10k in my trans. It was awesome to have a matching trans to my 3.2 and even better with the 3.6. |
| Steve |
Oct 23 2026, 09:45 PM
Many moons ago i helped Brad adding a custom cable shift solution to a 915 in a 914. It worked surprisingly well and costs a fraction of the side-shift kits available. I have a 915 that was meant to go with the 3.6L engine but i never got around using it. The plan was to do the same thing and go cable shift. (IMG:style_emoticons/default/idea.gif) Cable shift is still in business, but I don’t know if anyone still makes the rear mount for a 914. https://cableshift.com/product/ols/products/porsche-930 I noticed PMS also sells the cable shifters. Curious if they sell the rear mount. |
Lo-Fi Version | Time is now: 23rd October 2026 - 11:45 PM |
