> Adding Gauges need to see if wires exist, 73 Apperance group
kweiswurm
post Oct 23 2026, 10:10 AM
I am changing out the gauges in my center console. Don't need a clock but do want oil pressure and cylinder head temp. Oil temp exists as does voltage. Is there a spare wire I can use for the oil pressure sender to the gauge. The temps will use their own wire. Engine is 2.0 carbureted.Kweiswurm@itm-texas.com
dtmehall
post Oct 23 2026, 03:45 PM
QUOTE(kweiswurm @ Oct 23 2026, 10:10 AM) *
when i added an oil pressure gauge, I ran a new wire for it
FlacaProductions
post Oct 23 2026, 06:38 PM
I ran new lines - you'll need to for the CHT anyway. I pushed thru the speedo boot and hole.
post Oct 23 2026, 08:40 PM
Adding some nuance
If you are adding a single pole oil pressure gauge only and intend to get rid of the idiot light the wire is already there.
If you want to run a VDO dual pole oil pressure sender you’ll need another wire for the oil pressure signal.
Be aware that the dual pole pressure senders tend to have the low pressure idiot light set higher than the OEM 914 oil pressure sender and as a result, the dual pole senders may cause idiot light flicker at idle when hot. Just so you know what to expect.
dtmehall
post Oct 23 2026, 08:54 PM
thanks for that input.
fyi
i have been running a vdo dual sender for many years and have not experienced the flicker that you described.
could be that the quality on new senders are not as good?
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd October 2026 - 11:45 PM
