| Montreal914 |
Oct 24 2026, 10:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,213 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
There currently is a discussion in the classifieds about 914-6 oil tanks that drifted into other discussions such as filter location.
Link: http://www.914world.com/bbs2/index.php?showtopic=379458 What would be the cleanest way to move the oil filter from the stock 914-6 location to a vertical installation on the lower firewall? Can the filter console at the tank be capped with some U-turn? Zero experience with a 914-6 setup, but it seems like replacing the horizontally placed oil filter has a high potential of making a mess. (IMG:style_emoticons/default/confused24.gif) Or is there a simple trick? |
| mlindner |
Oct 24 2026, 12:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,806 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Montreal914, on the 914-6 you drain oil tank, the horizontal oil filter also drains. When removing the filter I place a paper towel under it....barely a drop. Best, Mark
Oct 24 2026, 12:02 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,952 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A small catch pan solves the drips. Why change something that works so well - on every 911.
| infraredcalvin |
Oct 24 2026, 12:06 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,779 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
This is fancy, you can trim one out of an empty plastic container, but it works, I end up using it for other uses too…
https://www.pelicanparts.com/More_Info/RENT...RwaAoA9EALw_wcB |
| Montreal914 |
Oct 24 2026, 12:34 PM
Simple enough! (IMG:style_emoticons/default/sunglasses.gif)
Stock location it will be. Thanks!! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 24th October 2026 - 11:53 PM |
