| young55961 |
Oct 26 2026, 04:37 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 15-March 18 From: Arcadia Member No.: 21,972 Region Association: Southern California |
Hi,
"I am replacing the fuel hoses for all the fuel injectors. I think I need to cut off the metal crimp/end, but I am not sure what is underneath or what kind of clamp to use to prevent fuel leaks ![]() |
| JeffBowlsby |
Oct 26 2026, 06:56 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,369 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Use clamps with smooth walls, a smooth edge to not cut into the fuel line. NOT the worm gear style. You will need a couple differnt siuzes depending on the fuel hose OD used, verify what is needed before ordering.
| L-Jet914 |
Oct 26 2026, 07:05 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I purchased a fuel injection hose clamp kit on Amazon that comes with various sized like the ones pictured on the right in Jeff's post.
| hndyhrr |
Oct 26 2026, 07:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 697 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest
Your local parts store should have them, I found them at HF in a nice box of various sizes.
Lo-Fi Version | Time is now: 27th October 2026 - 12:25 AM |
