| cabrioartie |
Oct 27 2026, 04:45 PM
Newbie ![]() Group: Members Posts: 44 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
I have a bulb out in the speedometer, so its even darker than it would normally be. I also just replaced a bulb in the tach by pulling out the gauge and being able to reach the bulb (there is just enough room).
But, it seems on the speedo it can't be pulled out enough to reach the bulbs. I assume it's either the speedo cable or the odometer reset cable. Oh, this is a '74. So, what is the best way to get to the bulbs and replace them? Looking a simple solution before I rip apart the dash. Thank you. |
| Ishley |
Oct 27 2026, 06:25 PM
Member ![]() ![]() Group: Members Posts: 370 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Disconnect the speedometer cable. I replaced all my bulbs with LEDs… except the alternator bulb which has to be incandescent.
https://www.superbrightleds.com/vehicle-lights |
| cabrioartie |
Oct 27 2026, 06:49 PM
Disconnect the speedometer cable. I replaced all my bulbs with LEDs… except the alternator bulb which has to be incandescent. https://www.superbrightleds.com/vehicle-lights Stupid question, how do I disconnect the Speedo cable? |
| emerygt350 |
Oct 27 2026, 07:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,797 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Definitely switch to LEDs. It will still be pleasantly dim but still useful.
Unscrew the speedo cable by becoming a contortionist |
| cabrioartie |
Oct 27 2026, 08:49 PM
| Ishley |
Oct 27 2026, 09:48 PM
As I recall… my Speedo pulled out far enough that I could reach in with a long
Needle nose pliers to loosen it up. Your situation may vary. Good luck. |
| porschetub |
Oct 27 2026, 11:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,193 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Definitely switch to LEDs. It will still be pleasantly dim but still useful. Unscrew the speedo cable by becoming a contortionist So I assume it can be unscrewed by reaching under the dash without removing the lower dash pad? Pretty certain the lower dash pad should be removed ,reach up and free the gauge from the rubber seal in the gauge surround this helps you get to the cable nut and then wiring after that . My experience with LED's was really not that great ,certainly not what i expected ,they don't project light well up the light tubes ,but expect this is better now with modern tech they should be better as this was years ago,i went to LED light strips as I like opening gauges.... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/slap.gif) ,cheers. |
| cabrioartie |
Oct 28 2026, 12:13 AM
Thanks everyone, I found another way without removing the speedo cable. With being able to pull out the speedo about an inch or so, and being able to pull out the Tach, I was able to reach in through the Tach hole and replace the bulb in the speedo.
Lo-Fi Version | Time is now: 28th October 2026 - 12:17 AM |
