> PMO owners, Enlighten me please.
post Nov 2 2026, 03:20 PM
PMO fuel pressure regulator. With the barbed nipples it is 8mm for all of them including the one for the stock size 9.5mm supply line. The AN6 fittings are 9.5. How did you get around this? This one has 8mm supply feeding two 8mm nipples to the carbs. Am I missing something, do they all need to be one size? I ve been all over town trying to find a 9.5 barbed fitting with no luck. I’d call PMO but I could only find a fax number. A little help would be great. Thanks
friethmiller
post Nov 2 2026, 04:18 PM
QUOTE(Shivers @ Nov 2 2026, 03:20 PM) *
Yeah Shivers... I just hit this problem a few days ago. I have the same set up. In a pinch, I bought a male to male 3/8" barbed union and reduced the hose to a 5/16" just before the inlet side of my PMO regulator. This seemed to work and it certainly eliminated the leak I had when using the 3/8" hose directly. If the inlet barb could be increased in size, that would be the better solution for sure.
From what I understand, 5/16" = 8mm and 3/8" = 9.5mm
UPDATE: Amazon has the correct unions for a better reduction. Perhaps the inlet can be had as well. What's the threaded size of the inlet barb fitting?
friethmiller
post Nov 2 2026, 04:43 PM
BTW, I figured out what PMO stands for .... Leaky Gas Box! Make sure all those fittings are tight.
post Nov 2 2026, 05:18 PM
QUOTE(friethmiller @ Nov 2 2026, 02:18 PM) *
I was actually hoping someone here would know It's not pipe thread, I think it is metric but otherwise I'm clueless. Thanks for the leak tip. I have some good pipe dope for the threads
infraredcalvin
post Nov 2 2026, 10:14 PM
Distracted Member
They make that part with AN fittings… I’d bet you can remove the barb fitting and fit a proper AN sized to your liking…
frank_c
post Nov 3 2026, 12:13 AM
QUOTE(infraredcalvin @ Nov 2 2026, 11:14 PM) *
I went the AN route. No leaks after ~12 years (knock on wood).
post Nov 3 2026, 03:26 AM
QUOTE(friethmiller @ Nov 2 2026, 02:43 PM) *
I ordered one of these, I hope it fits. I ID’d the threads the best I could. It will be here tomorrow, I’ll let you know if it will work.
- Lo-Fi Version Time is now: 3rd November 2026 - 06:39 AM
