> Sloppy fit from the factory?, Engine Cooling Flaps
Literati914
post Nov 4 2026, 03:14 PM
So is the engine cooling flap that’s on the Driver’s side (L) just a sloppy fit when the engine is warm/hot and the thermostat is expanded? The pics below are representing my engine in that state and you can see a gap at the bottom and outside edge.
The passenger flap (not pictured) is sitting solidly covering the oil cooler with no gap under it (as should be). And as you can see from the picture, this side can not “close” anymore than it is, because it fouls the small vertical tin in front of cylinder 2. So maybe what I’m seeing is an engineered gap ??
Correct for the driver’s side or no?
Literati914
post Nov 4 2026, 03:51 PM
Here a shot from the fan shroud side looking towards cyl #2 and there’s even a gap there too, highlighted by the screwdriver.
post Nov 4 2026, 05:13 PM
QUOTE(Literati914 @ Nov 5 2026, 10:51 AM) *
I had one similar on my last build,new pivot bushing but it never lined up ,turned out it was bent ??? had a spare and it was spot on ,not seen this issue before ...worth checking IMO ,good luck,cheers.
mgphoto
post Nov 4 2026, 05:58 PM
I’ve found 2 engines that had this flap glued closed with double sided tape. Not sure it was factory but the tape was exactly the same.
post Nov 4 2026, 06:42 PM
Not correct
Literati914
post Nov 4 2026, 06:57 PM
The cooling flap is definitely not bent.. the small vertical tin piece between the alternator and cyl #2 maybe, but doesn't look like it when not installed.
post Nov 4 2026, 07:02 PM
Tin is sitting too high. It’s either bent or something is pushing it up.
- Lo-Fi Version Time is now: 5th November 2026 - 07:35 AM
