> 915 leak, 915 leak
Biggles
post Nov 8 2026, 09:26 AM
Region Association: England
Hi All.
Wondering if anyone can help with a 915 gearbox leak that's developed on my car. I've cleaned the case but cant identify exactly where it's coming from but it's appearing off the clutch pulley mount. Any ideas? Do any of the bolts go through into the case in that area or are they tapped just into the case?
Thanks
Chris.
post Nov 8 2026, 09:47 AM
Pretty common to leak at the output flange.
Biggles
post Nov 8 2026, 02:05 PM
If you're referring to the drive shaft output its not in that area. It's on the clutch pulley.
- Lo-Fi Version Time is now: 9th November 2026 - 09:57 AM
