> WTB: Left 911 Boge 3.5" Strut, Wedge Pin type
frank_c
post Nov 8 2026, 12:03 PM
I'm looking for a left 911 Boge strut with 3.5" caliper bolt spacing & wedge pin for the ball joint (911-341-043-02).
As part of my 5-lug conversion, I went to install my freshly powder coated 911 Boge struts yesterday, and when attempting to slide in the Bilstein insert, I discovered that the left one is slightly bent - hence my search for a replacement.
Btw, if anyone has a use for a slightly bent left Boge strut housing - let me know (IMG:style_emoticons/default/smile.gif).
Thanks,
Frank
post Nov 8 2026, 12:24 PM
I know I have a left. I think it’s a 3 1/2. It’s in excellent condition. Can you post a picture of yours so I can make sure it matches up correctly. Thanks, mark
* I’ll be back at the shop in the morning.
frank_c
post Nov 8 2026, 01:55 PM
QUOTE(mepstein @ Nov 8 2026, 01:24 PM) *
Hi Mark,
Thanks very much for your fast reply here. Oddly, there are many right Boge 3.5" struts on eBay, but no left (IMG:style_emoticons/default/confused24.gif)
The circled strut on the left in the photo below is the one I'm looking for (green lines highlighting bent steering arm). Note that I need the strut type that is internally threaded for the gland nut.
Thanks,
Frank
post Nov 8 2026, 02:40 PM
I found a pic that I took a while ago. Unfortunately, it’s the external threaded type.
post Nov 8 2026, 02:45 PM
Ask on pelican. Typically, the right side strut is much harder to find. Rob, the owner of DC Auto told me most 911’s get damaged on the right side. I once went down to his facility looking for right side Bilstein struts. He had two on the shelf and over 30 left sides. His facility closed earlier this year.
frank_c
post Nov 8 2026, 03:49 PM
QUOTE(mepstein @ Nov 8 2026, 03:40 PM) *
Dang! Thanks for checking
QUOTE(mepstein @ Nov 8 2026, 03:45 PM) *
Yes, I'll try a WTB on Pelican next. I wanted to try here first due to the larger number of scammers on Pelican.
I may have more luck asking for a pair for folks who have them but don't want to split the set, and then just sell the right side.
post Nov 8 2026, 09:10 PM
@frank_c
date='Nov 8 2026, 12:03 PM' post='3277928']
Thanks,
Frank
[/quote]
I may have one. I have some singlr struts.
Will check tomorrow
post Nov 8 2026, 09:12 PM
@mepstein
' date='Nov 8 2026, 02:40 PM' post='3277936']
[/quote]
I may be able to use it.
I have a single with external threads but have to chech which side I have
frank_c
post Nov 9 2026, 12:03 AM
QUOTE(bdstone914 @ Nov 8 2026, 10:10 PM) *
Will check tomorrow
@bdstone914
Thanks Bruce. I'll hold off on posting a WTB on Pelican until I hear back from you.
-Frank
post Nov 9 2026, 03:43 AM
@frank_c
date='Nov 9 2026, 12:03 AM' post='3277994']
[quote name='bdstone914' post='3277984' date='Nov 8 2026, 10:10 PM']
Will check tomorrow
[/quote]
@bdstone914
-Frank
[/quote]
Ok. Will check Monday.
Where is yiu strut bent? The tube or arm? They can be fixed but cost is about $200.
- Lo-Fi Version Time is now: 9th November 2026 - 09:57 AM
