> 914-6 Relay Board, Labeling components
DennisV
post Nov 14 2026, 07:50 AM
In the process of trying to disable our fuel pump, I realized I didn't know what everything on the engine relay board was for. This thread was some help, but I'm still not 100%.
Can anyone confirm or clarify I have this labeled correctly? What are the fuses protecting?
P.S. I never did find a relay or fuse that disabled the fuel pump. (IMG:style_emoticons/default/confused24.gif)
barefoot
post Nov 14 2026, 08:06 AM
This should help (IMG:style_emoticons/default/beerchug.gif)
Barefoot
DennisV
post Nov 14 2026, 08:08 AM
QUOTE(barefoot @ Nov 14 2026, 06:06 AM) *
Thanks but that appears to be a 914-4 board. it is different.
rgalla9146
post Nov 14 2026, 09:49 AM
Dennis power for the fuel pump on a six does not go through the engine harness,
The round plug for the fuel pump comes from the chassis harness.
The 914 6 powers the fuel pump directly from the ignition switch without a fuse.
Ground is from a gang connection near the relay board
aturboman
post Nov 14 2026, 06:25 PM
QUOTE(rgalla9146 @ Nov 14 2026, 07:49 AM) *
Correct and the only way to disable the pump for other work with the key on is to unplug the pump itself.
2 Members: dtmehall, bob
- Lo-Fi Version Time is now: 14th November 2026 - 06:49 PM
