| rick 918-S |
Nov 15 2026, 08:05 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,381 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject.
| worn |
Nov 15 2026, 08:46 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,663 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| JamesM |
Nov 15 2026, 09:29 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,359 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject. Same stuff they slapped all over the 911s to seal the trunk. I believe @eric_shea might know. Some sort of rubberized wurth gunk if I recall. On 911s it provided some level of sealing of the front trunk around the shock towers but on the 914s as they sit behind the front trunk rear bulkhead seal, in the fuel tank compartment anyways that function was not needed. I think best guess was that it was used to identify the 6 tubs on the assembly line, but never saw anything definitive one way or another. Could be they did it for the same reason they did it to 911s without realizing its fairly pointless on a 914 tub. ran into a very original -6 in California and made a point to grab some pictures of how it was applied. much thicker than black paint, its almost like rubberized undercoating that was brushed on. Its an odd cosmetic detail on the -6s. Cool from an originality standpoint, but as the factory applied it over the top of the strut mounting hardware if you ever need to do an alignment you have to scrape it off anyways. |
| JamesM |
Nov 15 2026, 09:39 PM
| rgalla9146 |
Nov 16 2026, 07:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Obsess over details ?
1. From the pics it can be known the struts have been changed. 2. An alignment has been done. 3. It's likely a California delivery car. 4. The clip for the master cyl. strap is painted ? from the factory ? 5. The hood spring is on the strongest setting. Curious. 6. The 'one use' locking washer for the strut nut was not replaced. 7. Type 4 brake fluid. 8. Still has it's correct master cyl. cap. More ? I agree the original black goop around the strut top is a thick tar type material. I did not attemp to duplicate it on my long time original six. My bad. |
| DennisV |
Nov 16 2026, 08:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,062 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject. The factory workshop manual says in the Front Axle - Replacement of Support Bearing and Bearing Rubber section: QUOTE Use new permanently elastic sealing compound such as "National Glue 670" for pressure plates as well as supporting bearing. I poked around to try to find a description or modern version and came up short. Best I can tell, this isn't intended to have any bonding property. Just a sealant as the manual suggests. As such, I'm probably going to use Wurth Brushable Seam Sealer WRTH-8901021, which I've used in other areas. it is grey. So I might attempt to find something to tint it with so it appears more original. |
| JamesM |
Nov 16 2026, 09:47 AM
Obsess over details ? 1. From the pics it can be known the struts have been changed. 2. An alignment has been done. 3. It's likely a California delivery car. 4. The clip for the master cyl. strap is painted ? from the factory ? 5. The hood spring is on the strongest setting. Curious. 6. The 'one use' locking washer for the strut nut was not replaced. 7. Type 4 brake fluid. 8. Still has it's correct master cyl. cap. More ? I agree the original black goop around the strut top is a thick tar type material. I did not attemp to duplicate it on my long time original six. My bad. Just documenting the black goop. The fact that the car had been aligned makes it easier to do so and show that it is goop installed after the strut hardware gets installed and not black paint that goes on before hand/under. I personally wouldn't do it myself, especially on a freshly painted resto. Just to hard to cover nice paint with crudely brushed on black goop. But its still an interesting detail for anyone that wants it. |
| gandalf_025 |
Nov 16 2026, 09:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,537 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
| Literati914 |
Nov 16 2026, 10:07 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,419 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Did I miss the point of why it was done to begin with? maybe to highlight if movement occurs so the owner could catch it sooner than later?
Edit - Oh, perhaps so that things could go back to where they were easily, if the strut was changed out (IMG:style_emoticons/default/confused24.gif) Edit 2 - Duh, water ingress . |
| dr914@autoatlanta.com |
Nov 16 2026, 10:45 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,255 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| rick 918-S |
Nov 16 2026, 01:10 PM
probably could use rubberized undercoating I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject. I kind of like this suggestion. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 16th November 2026 - 08:36 PM |
