| andrewvolsen |
Nov 15 2026, 10:26 PM
Member ![]() ![]() Group: Members Posts: 76 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
I recently purchased this ‘74 and a large pile of spare parts. It was partially restored and is badged as a 2.0, has front and rear sway bars, etc. The engine is an EC case with non-2.0 heads and Weber carbs. I was told it was rebuilt to a 2056, but the guy who was working on it isn’t able to answer any questions about it (sad story), so I don’t really know what it is now or what the car started as.
It had been sitting for at least a year when I picked it up. I got it running last weekend and drove it around the neighborhood. It pulled pretty hard - felt like more power than I remember in my past 1.8s. While working on the carbs I noticed that the engine had no cooling flaps under the tin and it was leaking alot of oil from the bellhousing. This weekend I pulled the drivetrain out of the car and stripped it down to a long block. Here’s what I noted during the disassembly:
Any suggestions on what caused the mangled flywheel ring gear teeth? The teeth on the starter pinion gear look pretty normal. Should I replace the flywheel? I was previously posting about this car here, but the project scope has grown beyond the title of that thread: http://www.914world.com/bbs2/index.php?sho...379606&st=0 Attached thumbnail(s) |
| JamesM |
Nov 16 2026, 12:13 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,359 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Lots of interesting stuff here.
Mangled teeth on the flywheel could be a number of things. Kickback due to improper timing at some point, hitting the starter with the engine running, crappy starter, stuck solenoid, crappy flywheel, hard to say. From the looks of it it appears the teeth may be eaten all around the flywheel? If so I would suspect less that the issue was due to kickback. Given there are a lot of questions here I would say play it safe and replace it. Where is that oil from on your engine main seal there? You may be able to repair the heat exchanger flanges but that can be a crapshoot, the metal on the stainless ones is fairly thin and may have torn when it was over torqued but from here the break appears to be at the welds. Shift rod was most likely damaged when someone pulled the motor at some point, so guessing it may have irregular bends elsewhere as well. Probably have a better overall experience if you just replace it. Hopefully the engine wasnt run very long without the cooling flaps like that, thats a good way to cook things. Did the seller say he built the motor himself or did he just install it? I see some familiar signs on the motor but then others that I know a particular builder wouldn't normally do. I suspect it has a cam and/or larger valves due to the dual springs, the heads have been gone through for sure and the case has been apart but given the quality of the install there is no saying what state the motor is in overall. IF it is a 2056 than 51cc 1.8 heads are going to give you a healthy compression ratio at which point would also lead me to suspect a large duration cam. Aluminum pushrods, and no swivel feet adjusters or solid spacers though. 44s are a big carb to throw on a 1.8 All together its a little strange. Can you tell at what RPM it starts to come on cam? You already have the engine out and the tin off. If it were me, given the missing cooling flaps and unknown displacement, I would pop the 3-4 head off and get a better idea of what you are working with. any idea what the oil pressures were looking like? |
| andrewvolsen |
Nov 16 2026, 10:56 AM
Mangled teeth on the flywheel could be a number of things. Kickback due to improper timing at some point, hitting the starter with the engine running, crappy starter, stuck solenoid, crappy flywheel, hard to say. From the looks of it it appears the teeth may be eaten all around the flywheel? If so I would suspect less that the issue was due to kickback. Given there are a lot of questions here I would say play it safe and replace it. I'll pull a flywheel off one of the core motors and have it resurfaced. Where is that oil from on your engine main seal there? It dribbled out after I pulled the flywheel. It looked pretty dry back there before removing the flywheel. All of the oil in the bellhousing felt and smelled like gear oil. Did the seller say he built the motor himself or did he just install it? I see some familiar signs on the motor but then others that I know a particular builder wouldn't normally do. I suspect it has a cam and/or larger valves due to the dual springs, the heads have been gone through for sure and the case has been apart but given the quality of the install there is no saying what state the motor is in overall. IF it is a 2056 than 51cc 1.8 heads are going to give you a healthy compression ratio at which point would also lead me to suspect a large duration cam. Aluminum pushrods, and no swivel feet adjusters or solid spacers though. 44s are a big carb to throw on a 1.8 All together its a little strange. Can you tell at what RPM it starts to come on cam? The person I bought the car and parts from was selling on behalf of the owner. As I understand it the owner had a serious health problem and was no longer able to deal with this stuff or answer any questions about it. The only info I have about the motor beyond what I've observed is "his brother said it's rebuilt to a 2056." I've only driven it once and it was not well tuned, but it felt like it was not making much power below 2500 rpm and was still pulling strong when I shifted at ~5800 rpm. You already have the engine out and the tin off. If it were me, given the missing cooling flaps and unknown displacement, I would pop the 3-4 head off and get a better idea of what you are working with. any idea what the oil pressures were looking like? What should I look for - valve and cylinder sizes, general condition? Is this something I could do with a borescope through the spark plug hole, or better to pull the head? It doesn't have an oil pressure gauge. The oil pressure light came on I when turned the ignition on, then promptly turned off when the engine started. |
| JamesM |
Nov 16 2026, 11:22 AM
The person I bought the car and parts from was selling on behalf of the owner. As I understand it the owner had a serious health problem and was no longer able to deal with this stuff or answer any questions about it. The only info I have about the motor beyond what I've observed is "his brother said it's rebuilt to a 2056." I've only driven it once and it was not well tuned, but it felt like it was not making much power below 2500 rpm and was still pulling strong when I shifted at ~5800 rpm. I think signs point to it being a 2056 with a healthy cam then. Definitely not a stock 1.8 What should I look for - valve and cylinder sizes, general condition? Is this something I could do with a borescope through the spark plug hole, or better to pull the head? It doesn't have an oil pressure gauge. The oil pressure light came on I when turned the ignition on, then promptly turned off when the engine started. My two reasons for pulling the heads were first to determine what you were working with and second to determine if running without the cooling flap had caused any damage. At this point I don't think you need to determine exactly what it is you have there, its a built motor. Still some concerns around if any damage was caused to the heads/bearings but at this point not even sure its worth pulling the heads to find out as the only thing you would be doing with that information is rebuilding the motor, and it sounds like it was potentially running strong. Maybe do a leak down test. Compression test might be difficult with the motor out of the car, but aside from that I would probably just clean it up, fix some of the oddities, and run it. Maybe make some changes to the valvetrain with the addition of swivel feet adjusters and solid rocker spacers and properly sized steel pushrods as when tuned properly that thing is going to want to rev. |
| brant |
Nov 16 2026, 11:35 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,293 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
It could also be built as a 1911 depending if the builder changed the rods and crank during the rebuild
Changing the trans output shaft seal is something I do frequently when ever the trans is out. Easy and only around 10$ The lack of low end on the power can also be a symptom of the carbs being too big |
| 914sgofast2 |
Nov 16 2026, 11:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 817 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
That's a nice looking 914, especially in that color. As others have said, I would just one of the heads off in order to determine if the engine is indeed a 2056cc.
The oil leak in the bellhouisng looks like it is gear oil leaking from the transmission, not the engine. That flywheel is toast. Replace it, along with the clutch disc. The poor running of the engine at lower rpms is likely due to someone putting a "racing cam" in it, which will never have much low speed torque below 2500rpm. Big carbs with big venturis that are too large for the engine displacement will also make it run like you described. Again, this points to the need to remove one of the heads and figure out the displacement before you start trying to tune the carbs and changing carb jets. I would also take apart one of the carbs to figure ot what size venturis they have. If the venturis are simply too big, you will never be able to make it a good running street engine. An engine tuned (or built) for racing, will never be happy running at the lower rpm rev range needed for a tractable street engine. |
| VaccaRabite |
Nov 16 2026, 12:38 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,944 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Someone has definitely cooked here....
Seeing the oil galleries plugs like that is a good sign. It could be a 2056 or it could be a 1911. Both will have 96mm pistons, and you will have to measure stroke to find out which it is. Usually a 1.7 or a 1.8 will be a 1911, since they already have the crank on hand. Correct me if I'm wrong but this car had IDF style 44s right? I don't think its mentioned in this post. Years ago when I first built my 2056 I was also running 44s. It had ZERO power until 4000 rpm, and then would set you in your seat through redline. I also agree that cam choice makes a huge deal. I ran a 494, and another cam based on the Web 494. Car would simply not idle under 1000 RPM and was happiest at 1100. Many cams will trade low speed drivability for high end power - fun on a track, hard to drive on the street. Unfortunately there is not a good way to tell what cam is in there without a full on tear down. Cam change on a VW derived engine is not a simple task like it is on most cars. The flywheel - did it have a smaller high torque starter? Those can be known for tearing up the flywheel teeth if they are not properly spaced out. Heat exchangers were overtightened at the heads - probably had trouble getting the SSIs to seal - common. They are fragile and the ears tear just like you see. They can be re-welded but they will crack. Especially if they are old and have been heat cycled a million times. Zach |
| andrewvolsen |
Nov 16 2026, 12:58 PM
I would also take apart one of the carbs to figure ot what size venturis they have. If the venturis are simply too big, you will never be able to make it a good running street engine. An engine tuned (or built) for racing, will never be happy running at the lower rpm rev range needed for a tractable street engine. I measured one of the venturis when I rebuilt the passenger side carb before deciding to pull the motor - 32 mm It could be a 2056 or it could be a 1911. Both will have 96mm pistons, and you will have to measure stroke to find out which it is. Usually a 1.7 or a 1.8 will be a 1911, since they already have the crank on hand. It could go either way. It's an EC case, but the guy had lots of 2.0 parts. I got 3 GA cores with it. Correct me if I'm wrong but this car had IDF style 44s right? I don't think its mentioned in this post. Years ago when I first built my 2056 I was also running 44s. It had ZERO power until 4000 rpm, and then would set you in your seat through redline. That's right, Spanish Weber IDF 44s with 32mm venturis. I also have a pair of Dellorto DRLA 40s in a box, but the Webers were on the car when I bought it. The flywheel - did it have a smaller high torque starter? Those can be known for tearing up the flywheel teeth if they are not properly spaced out. The starter on it when I pulled the engine was stock type, but it could have had something else in the past. |
| FlacaProductions |
Nov 16 2026, 01:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,296 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
| andrewvolsen |
Nov 16 2026, 01:39 PM
Lo-Fi Version | Time is now: 16th November 2026 - 08:36 PM |
