| Highland |
Nov 16 2026, 03:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I've read all the threads and it seems like there will be an expert technique, then someone else chimes in and says it's wrong.
I'd like to know if I can lift the whole rear end with a jack under the engine bar and under the sub frame bar to lift the front end. I would of course use a wood block in between the jack and car then place supports under the "donuts". |
| rgalla9146 |
Nov 16 2026, 04:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I've read all the threads and it seems like there will be an expert technique, then someone else chimes in and says it's wrong. I'd like to know if I can lift the whole rear end with a jack under the engine bar and under the sub frame bar to lift the front end. I would of course use a wood block in between the jack and car then place supports under the "donuts". My car is low. In the front I use a high quality, knot free 30" 2x4 between the front mounts of the lower control arms. The board may flex up and touch the front of the pan. I lift untill the front tires are off the ground then lower the car and switch to a 4x4 (which will now fit) for additional strength and lift. An alternate method is to roll the front tires uo onto short 2x4s In the rear I place a 2x4 or 4x4 block under the rear of the transaxle. Take care to avoid speedo cable and rear shifter attachments. I've done this hundreds of times on hundresds of cars. These methods are safe on flat, hard, smooth surfaces. After lifting, strong, quality jackstands are manditory. |
| Root_Werks |
Nov 16 2026, 06:51 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,093 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I'd pass using the engine bar to support a 914.
In the rear, I'll use the transmission (let the scolding begin). In the front span a 2x4 across A-arm mounts. Guess also depends what work is being done where and how you lift. Haven't tried using a factory jack point off a Long in 40+ years. |
| Shivers |
Nov 16 2026, 07:34 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,720 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| bkrantz |
Nov 16 2026, 08:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,821 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I also use the longs but my method is to use a piece of 1/2 by 2" hardwood about 18"long. I put this alongside the seam, plus a short length of 2x4 on the jack.
Once my car is jacked up I put jack stands under the donuts. I did put reinforcements on the floor pan to strengthen the donuts. |
Lo-Fi Version | Time is now: 16th November 2026 - 08:36 PM |
