> Engine install
bajafreaks
post Nov 17 2026, 11:37 AM
Gearing up to finally install my motor and trans back in the car. I remember the axles being in the way when I pulled it, is it possible/difficult to install them (stub axle and axle assembly) after the motor is in place but no heat exchangers/exhaust installed yet?
Steve
post Nov 17 2026, 11:47 AM
QUOTE(bajafreaks @ Nov 17 2026, 09:37 AM) *
I had no problem installing or removing the axles with the motor and trans in place. But yes, the exhaust / headers / heat ex-changers were removed at the time. The axles need to hang down to remove them or install them. When installing the motor and trans I usually tie the cv's / axles up so they don't get in the way.
-Steve
bkrantz
post Nov 17 2026, 08:26 PM
I have dropped and installed engines with or without exhaust installed. It requires pausing at the right heights to swing the axles around for clearance. And some double bags on the greasy CV joints to minimize mess.
1 Members: Ron914
- Lo-Fi Version Time is now: 17th November 2026 - 09:21 PM
