| jmargush |
Nov 20 2026, 06:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I put a high performance clutch in my car before this past driving season.
High performance in that the lining is a bit grippier and the pressure plate springs are stronger. a while after installing it I noticed it felt like it wasn't releasing completely, so I tightened the cable some more. After 3 or 4 months of driving I am experiencing again the clutch not releasing all the way. I can feel a tugging when i start the car in gear, and if I come to a stop after driving and try to get it into reverse it just grinds. Maybe it is in my head but the pedal feel doesn't feel quite the same. I am getting the feeling like possibly the bracket in the tunnel is starting to let go from the extra force of the stronger springs. Does this sound like a logical possibility? How far should the release fork move to get the clutch all the way off the flywheel? or do I need to investigate with a borescope in the tunnel to see if I can see any thing? |
| stownsen914 |
Nov 20 2026, 09:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,036 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Tell us a little more about the clutch. Uprated version of stock type 215 mm?
Lo-Fi Version | Time is now: 21st November 2026 - 12:27 AM |
