| seanpaulmc |
Nov 21 2026, 04:42 PM
Member ![]() ![]() Group: Members Posts: 484 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
Stuck bolt. Any home remedies on this one?
Driver side rear lower shock bolt. Won’t budge. Doesn’t turn in the hole. Tried a C clamp. Tried BFH, as best as possible with the awkward angle (rotor removed). Will continue to add penetrant. ![]() Heat? Find someone with a press and take the whole trailing arm? Ugh! Other side was stubborn. This side just says No Way! TIA World. Cheers, Sean |
Nov 21 2026, 07:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,186 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Heat is almost always the solution to a stuck (inset part name here) problem.
The important technique is to heat the hole, not the bolt. This expands the hole size, breaks rust bonds, and reduces friction. How? Wrap the bolt in a soaking wet cloth this keeps the bolt cool and the soaking wet aspect keeps it from accidentally catching fire. Even if it doesn’t work the 1st time. Respray with penetrating oil, let cool, reheat, repeat. Each heat & cool cycle allows the penetrating oil to get in a little deeper. Pretty rare that the fire wrench doesn’t win in the end. Note of Caution: Be careful with all that oil, undercoating, or whatever is all over that trailing arm. I’d wire brush that crap off before trying the fire wrench. Common sense dictates having a fire extinguisher at hand when working with fire. These small fire resistant mats used for sweating copper plumbing are the bomb. Soak it in water, wrap the bolt, and then you only need to worry about whatever is all over your trailing arm and the rubber shock bushings. ![]() |
| bdstone914 |
Nov 21 2026, 08:02 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Heat is almost always the solution to a stuck (inset part name here) problem. The important technique is to heat the hole, not the bolt. This expands the hole size, breaks rust bonds, and reduces friction. How? Wrap the bolt in a soaking wet cloth this keeps the bolt cool and the soaking wet aspect keeps it from accidentally catching fire. Even if it doesn’t work the 1st time. Respray with penetrating oil, let cool, reheat, repeat. Each heat & cool cycle allows the penetrating oil to get in a little deeper. Pretty rare that the fire wrench doesn’t win in the end. Note of Caution: Be careful with all that oil, undercoating, or whatever is all over that trailing arm. I’d wire brush that crap off before trying the fire wrench. Common sense dictates having a fire extinguisher at hand when working with fire. Try heat as suggested Keep in mind there is a rubber bushing the metal sleeve runs thru. That shock looks shot from the amount of rust. Try to get the bolt to turn. Put the nut back on flush with the end of the bolt. Put one hammer against the nut an strike it with a heavy hammer. |
Nov 21 2026, 08:11 PM
Put one hammer against the nut an strike it with a heavy hammer. If you have air tools at your disposal - an air hammer does wonders due to the rapid fire impacts. But as Bruce is pointing out, you need the nut on the threads to prevent accidental damage. |
Nov 21 2026, 08:19 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,007 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Yea, my guys would use an air hammer on that. Taking it off and using a press sounds like a good option as long as the bolts on the suspension console aren’t just as stuck as the big one. The suspension console bolts are typically a tough one to remove without snapping off in the console itself.
Lo-Fi Version | Time is now: 22nd November 2026 - 12:35 AM |
