> MSD Sparkplud connectors
DavidSweden
post Nov 23 2026, 11:32 AM
Region Association: Scandinavia
Hello,
I've rebuilt a 2.2T and will be using an MSD 6AL ignition system. As I understand it, I need to replace the original Beru spark plug connectors when using the MSD system.
Can anyone advise which spark plug connectors I should use as replacements for the Beru connectors?
Thanks in advance
VaccaRabite
post Nov 23 2026, 12:22 PM
En Garde!
You need to replace the entire spark plug wire, not just the tips.
You want to use spiral wound wires. I would call MSD, they will be able to point you to the exact wire you need, or you may have to make them (not hard). 8.5mm silicone wires, and the part about being spiral wound and not solid core is important. Feedback from the solid core wires will burn out the MSD unit over time.
Zach
- Lo-Fi Version Time is now: 24th November 2026 - 01:35 AM
