> I have two 4 cylinder engine cases ..., What would you do?
GeorgeKopf
post Nov 24 2026, 09:03 PM
I have a WO engine case and an EA engine case.
I also have:
a set of weber dual 40mm carburetors
a pair of stainless steel 2.0 heat exchangers
a pair of stock 2.0 heads
All of the rest of my engine components are from a 1.7 liter (crank, cam, pistons and rods)
I want to keep the factory heat exchangers so that I can have cabin heat.
I could build the EA case to be a naturally aspirated 2056.
I could build the WO case to be a fuel injected 2270.
Either way, I need to buy a new crank, cam, rods and pistons.
I understand that the 2270 will be hobbled by the stock heat exchangers, but I also believe that it will have more torque making the car more responsive.
I could build the 2056 first, get the car on the road and then worry about the 2270 if I think it necessary.
I'm not looking for a definitive answer. I'm just soliciting the communities expert opinions and hoping to have a conversation.
Thanks.
George
post Nov 24 2026, 11:44 PM
QUOTE(GeorgeKopf @ Nov 24 2026, 11:03 PM) *
I think you probably need to resolve what your expectations are.
In either engine instance - you’ll still be slower 0-60 than a 2026 Toyota Camry. The 2270 might get you on par depending on cam, headwork, but probably not on stock heat exchanger exhaust.
914’s are momentum cars no matter which way you slice it . . . Always have been . . . Always will be. If the goal is to be fast you need to be fast in the corners. Neither of those engines will be fast in a straight line.
If the goal is to simply enjoy the car for what it is, a snapshot of history and enjoy an analog experience that is impossible to find in a modern car, either of those engines will get the job done. Then it just comes down to how much do you want to spend to go X% faster off the line.
Just a perspective to consider.
- Lo-Fi Version Time is now: 25th November 2026 - 01:51 AM
