Full Version: WTB'74 2.0L ECU
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
jesse7flying
Looking for a good ECU for a 1974 2.0L car. The Bosch part number is 0 280 000 043 or 044. If you have one, please let me know. Thanks
Regards--Jesse
duplicate
QUOTE(jesse7flying @ Feb 8 2025, 12:34 PM) *
Regards--Jesse
Isn't the one you are getting from @Montreal914 correct? if not I may have one
Mine has a Bosch tag that says remanufactured.
Unfortunately the original tag isn’t there anymore.
Fun fact, this ECU actually came with the core 2.0 engine I bought from you @bdstone914 over 12 years ago when I rebuilt my engine to 2056. smile.gif
Click to view attachment
EDIT: actually Jesse, look at the number on the ECU. It does match the ECU for a 73 2.0 liter. 280 000 037 and the CU13X.
@Montreal914
date='Feb 8 2025, 05:24 PM' post='3191009']
I think what matters is the compatibility of the components like ecu mos . I would refer to Brad Anders site to see what components are in the 74 FI system are and which ecu is compatible
[/quote]
CU14X is correct for a 1974 2.0L ECU.
jesse7flying
I can see this thread is causing some confusion, so let me try to explain. Yes, I am buying a '73 D-Jet system from Eric (Montreal914) and he has been up front about the system being untested and possibly not working. Yes, the ECU coming with Eric's system is for a '73 D-Jet (CU13X).
The reason I'm looking for a '74 ECU (CU14X) is just to hedge my bets on cobbling together a good working system. My reading of the excellent pbanders D-Jet analysis document recommends using '74 parts for a '73 engine due to parts availability. The '73 and '74 ECUs are not interchangeable. Also, I have a working 043 MPS and that, along with a working '74 ECU might be, in the long run, the best solution to getting a working D-Jet system in my car. If my reading of the issue is incorrect, I'm open to correction. Hopefully, I have not muddied the waters even more. I appreciate you guys helping and keeping me on the straight and narrow.
Jesse
Think I may have one in warehouse. Will look tomorrow.
jesse7flying
Thx Mark
It was a 052 not 044
cgnj
@jesse7flying
I opened op my box of ECUs. I have a 044 ECU. I PMed you
Invision Power Board © 2001-2026 Invision Power Services, Inc.
